Results 1 to 10 of 16
Thread: W-Body Suspension Upgrades
    Post W-Body Suspension Upgrades
    I'm Posting this as a thread that ALL Avilable
    W-body Suspension Upgrade Parts Can be listed here for a
    convenient location that ALL can easily refer to.
    SWAY BARS:
    FRONT;
    GM 34mm Sway Bar #26024362
    ( All W-bodies WITH 3.4 DOHC, 3800 V6, OR FE3 Suspension have it )
    REAR;
    (stock is 12-14mm)
    Addco 7/8" Sway Bar Part #474
    (All 1st Gen. W-body except 95-99 Monte Carlo and Lumina)
    Addco 7/8" Sway Bar Part #639
    (1995-99 Monte Carlo and Lumina)
    Trailing Arms:
    GM Tubular Trailing Arms #12498649
    (Comes as a pair, complete with bushings)
    (Fit 1st and 2nd Gen. W-bodies)
    BRAKES:
    FRONT ROTORS;
    Powerstop Cross-Drilled (Vented):
    10.5" #AR-8228
    11.25" #AR-8254
    REAR ROTORS;
    Powerstop Cross-Drilled (Solid):
    10.1" #AR-8251
    11" #AR-8229
    1991 Grand Prix STE
    3.4 DOHC
    1 of 792 Produced
    Extensive Mods Done
    1991 Lumina Z34
    3.4 DOHC
    Getrag 284 5spd
    1 of 30
    FYI-
    BMR lateral bars work in the rear of the 95-99 Monte Carlos
    Held Motorsports made STB's (front and rear). I do not know if they still sell them. The older rear bar had a poor design. They also make various other upgrades like coilovers, though Shane hated his that had their old design- too noisy. The new coilover design was supposed to cure the noise issues, but I haven't heard much about it.
    Tim
    325 whp 350 lb-ft
    W-body RSTB Maker AWeb80's Avatar
    Feb 2004
    Lincoln, Ne
    385
    I make Rear STB's for all first Gen W's except the Cutty verts.....
    Rear STB's FOR SALE for all W-body's (except Cutty Verts). PM me for info
    Tons of pics of my mods
    Jan 2004
    Lagrange Georgia
    261
    is their any way to put a rear stb on a cutty convert.... and still be ablle to put the top down
    1994 Cutlass Supreme Convertible 3.4 DOHC
    1969 Oldsmobile 442
    1997 Chevy Tahoe
    http://members.cardomain.com/mperkins442
    Feb 2004
    Lincoln, Ne
    385
    Quote Originally Posted by Mitch DOHC View Post
    I've looked at a few in J/Y's and i'm not sure how to do it.....
    its prolly possible...but it might get funky.
    Apr 2007
    Whitelevel/louisburg, NC
    49
    Quote Originally Posted by AWeb80 View Post
    Id imagine you would have to do it down low on the strut tower or put some big bends in it, both of which will make it not work near as well and not really worth it.
    Feb 2007
    Mansfield,Ohio
    101
    What site are these part numbers from?
    parts needed to make your own coilovers (appx. $150-200)
    sleeves: http://www.a1racing.com/index.asp?Pa...OD&ProdID=1734
    nuts: http://www.a1racing.com/index.asp?Pa...OD&ProdID=1744
    any of these springs should work: http://store.summitracing.com/egnsea...115+4294787535
    you can use the stock mounts and stock struts. you may have to modify the top of the strut body for the sleeve to fit over it
    91 GTP HM-284 GONE
    96 Special Edition LQ1/4T60E GONE
    98 Spawn of Satan (L67 Regal)
    87 V10 SM-465/Mild 350
    06 Cobalt SS/SC GONE
    Jan 2004
    Central Wisconsin
    516
    Does any know about better control arms for the front of a Cutty? I know the '97+ GP's have better options, but what about us first gen cars? I NEED to get a set.
    Aweb80...how much for a rear STB in a Cutty sedan?
    Can I take the first gen strut upermount to fit on 1.5gen coilover ?
    I want take the 1.5gen suspension systeme to put on my GTP 1994, I have a lot of pieces crap on my firt gen .. and I want swap at coilover with a 1.5Gen, but I don't know when put the first strut upermount in 1.5gen strut coilover .. thanks !
    Sorry for my Bad English, I talk French, Thank's for your comprehension !
    Pontiac Grand Prix GTP 1994 V6 3.4L DOHC
    Swaped Manual 5spd HM-284 http://www.cardomain.com/id/elsunfire
