Results 1 to 10 of 15
Thread: 3400 Timing chain upgraded?
    Warsaw, IN
    12,993
    3400 Timing change upgraded?
    THe older blocks all use a 20/40 tooth setup. In 2000, the 3100 and 3400 both got a 25/50 tooth setup. Is there a reason GM went with more teeth/linkages? Which would be stronger by design? Im looking for the strongest timing chain I can put on a 3400.
    hmm good question, I have a 99 engine, id be intrested to know this as well.
    1995 Monte Carlo LS
    3400 SFI 60v6
    FFP Underdrive Pulley, S&S Headers, LSD, ODBII Swap, DHP
    Topeka, KS
    9,128
    Looking at a couple press releases on some other new 660s, higher tooth chains are for NVT issues, not necessarily strength. Since GM has been pushing for improved NVT on these engines over the past several years, I'm betting that is the reasoning. So if you want a quieter chain, go with the higher tooth count.
    Perpetual Learner boarderbob's Avatar
    Jan 2006
    Between here and there, Now
    21
    Forgive my ineptitude, but what is NVT?
    Health is merely the slowest rate at which one can die.
    If guns kill people, then I blame my bad spelling on my pen.
    Photo Gallery
    Topeka, KS
    9,128
    Noise, Vibration and something else I can't remember...
    ...ticking?
    Brian
    3400 SFI V6, 4T60e
    mine hp/w8 will pwn j00z
    Connecticut
    639
    Noise Vibration Techniek i think according to google results
    that may explain why many 00+ engines see even with 70-80k miles are quieter than my 99 3400 with 90k 85k on it.
    1995 Monte Carlo LS
    3400 SFI 60v6
    Peoria, IL
    1,060
    I always heard NVH (Noise, Vibration, Harshness).
    '99 Z-28 - Weekend Driver
    '84 X-11 - Time and Money Pit
    Quote of the week:
    Quote Originally Posted by Aaron
    Topeka, KS
    9,128
    Maybe it is NVH... That makes more sense. At least I got 2 out of 3 correct. :P
