Page 4 of 4 FirstFirst ... 234
Results 31 to 34 of 34
Thread: I Mega Squirted my car ("how to" w/pics)
  1. #31
    is the gpio board going to just be an add-on board, or will it be a new base board?
    im thinking about using one on my fiero project (3.4l camaro engine) running boost and NOS.
  3. #32
    I did not read the post, but is this better than the obd 2 swap?
  4. #33
    th gpio is an add on board designed to do things like transmission controll, abs, stability controll, body controll, basicly whatever you can dream up. they are also working on a router board, wich is an add on board for sequential fuel injection and full coil on plug ignition. eventualy the router board will be worked into a full computer, either called megasquirt 3 or ultra megasquirt.
    if you are going to run nitrous and boost, look into megasquirt 2/extra code. they are working on getting the boost and nitrous controll integrated into it. if you go with a megasquirt 1/extra it already has all those fetures in the code and well proven. you do need to make some hardware changes to make it work though.
  5. #34
    Quote Originally Posted by d.o.h.c View Post
    you better believe it
