Yeah, they don't last as long but they are excellent for limited use engines. If you plan to pull the rods out and replace them more often, aluminum is the way to go. Not practical for street use.
Aluminum Rods tend too stretch and I've never seen a manufacturer recommend them for any street/endurance application.
How long are LS7 Rods?![]()
Heavy Duty 5spd Getrag? Does anyone know what ratios, and final drives are available?
aluminum rods yes are for racing applications.
But if you just gotta have them,....
http://cgi.ebay.com/ebaymotors/SBC-A...QQcmdZViewItem
k, my acadian has had a couple trips to 8500+ w/o a healty oilpump.. so without doubt I had a rod knock after.. so i babyed it for like a month.. and just this past weekend I took it out for a last run with my buddy folowing me in his truck.. and I went straight to the highway.. i held it in 3rd gear.(373 gears) at some 150kph.. it was reving in the means of aboot 9500+ untill the rev limiter that is built into my ingitin system kicked in.. the point of the story is.. i held it like that for about 2miles before it finaly gave way an ended by a snap and a rod threw the side of the block.. so if you can do that with a shitty old 2.8L with a screwed rod.. it is clearly... Possibale with a ballenced engine.. ( by the way juss to let yall know how much of a trooper the little 2.8L was it started for a second even after the rod went clearly threw the block...)
Six-t-Six Motorsports
2.8L Chevette Roadcar
3.2L Acadian Racecar
Ohh ya and my whole incodent that i did there is video to prove it.. so if i could put it somewere on the net yall'd be able to see it
What cam is in that thing? How was it even possible to keep going higher and higher?
