Results 1 to 4 of 4
Thread: 3100 Cylinder Head Bolt Retorque?
    I've got a question for 3100 buffs.
    I replaced head gaskets on my 95 Grand Prix 3100 about 30, 000 miles ago and the lower intake gasket is starting to leak coolant. I plan on replacing the lower intake gasket soon. What I'm wondering is if its a good idea to retorque the cylinder head bolts at this time and if so what should I retorque them to? I had the heads milled, used new GM head gaskets, and installed new head bolts.
    Also, who makes the best lower intake manifold gasket?
    Topeka, KS
    9,128
    RE: 3100 Cylinder Head Bolt Retorque?
    If you are replacing the lower intake manifold, go with the latest GM gasket which fixes the leakage issue. There is a TSB on here somewhere, or just do a search for it. It will give the part number for the gasket, as well as the revised torquing sequence and values.
    As far as the head bolts go, I don't think it would be a good idea to try to retorque them.
    Surrey, BC, Canada
    5,830
    You cannot. The bolts are torque to yield. You need to torque them with a torque angle meter. There is no Foot Pount torque value for the final pass.
    on a stock motor, retorquing is not needed.
    on a modified engine, i would recommend it,
    modified meaning high compression ration or boost.
    i have personally experienced the head bolts loosening up over time and i swear i have read a gm note somewhere to retorque the head bolts after a few driving sessions.
    i will be retorquing mine.
    you dont really have to "retorque" them, just check to see with a socket and wrench and give it a little "umph"
    if its noticebly loose, retorque it.
