Results 1 to 5 of 5
Thread: injector wiring harness
    ok i have not checked yet but tomm. i am, i think i may have switched the 135 injectors connectors witht he 246, would the car run? i am expeirienceing a small backfire in shift, flames at shift and poor fuel economy?> is there a way to kno which are for the fron bank and which are for the rear?
    vrrrooooooooooooooooom i need new exhaust
    wiring is right, timing seems good, what else could be causing this back fire
    6,264
    The front injector wires only have connections for the injectors, the rears have hookup for the EGR, TPS, and IAC. How are your plugs/wires? Reason I ask is flames usually indicate alot of raw fuel passing through the exhaust.
    plugs wires are all new, the car feels liek it has has no schabang!
    6,264
    You might have a stuck injector. Or maybe you have a coil pack going bad. Possibly your timing might be of.
