Piston Pin Removal/Installation Revision
Gasket Surfaces - Use of Surface Conditioning Discs
Oil Odors
Tick or Rattle After Start-Up
Surface Conditioning Discs Precautions
Ignition - Engine Miss, Updated Spark Plug Wires
Lower Intake Manifold - Revised Tightening Procedure
Timing Chain and Sprocket - Revised Installation
Pushrod Identification Revised
Engine Rocker Cover - Oil Leak
Accessory Drive Belt Tensioner - Knocking Noise
Diagnosing Intermittent Idle Speed Increases
Engine Vacuum Testing
Lower Intake Manifold - Revised Tightening Procedure (2004 Update!)
