FAQ Members List Calendar Mark Forums Read
Go Back   60DegreeV6.com > engine ground cleaning for the 60 degree V6
Support the Site!
Like what you see here? Support the site to help us continue to grow.
Search Content
Navigation
Motor Articles
In Depth Articles
Miscellaneous
Stuff from our Store
Support this site by buying our stuff!
Welcome to 60DegreeV6.com
Welcome to 60DegreeV6.com, the best source for all your GM 60º V6 needs.
If you have a question, please visit the forums and ask there. If you would like to add content to the site, visit the "Create Content" link on the navigation menu. We are always looking for people to add content to the site in order to further expand the site to continue to benefit the community.
Forum Tag Cloud
2.8 hybrid 3.1l 3.4 3.4 camaro 1994 rwd 4t60 3100 3100 head porting 3400 3400 head porting 3500 3500 rods alternator automatic beretta performance boost boosted brad built burette camber centrifugal client compression convertible copper gaskets copper head gaskets corsica crank trigger csc dohc double roller eagle h-beam ecm electronic email engine fire fiero forged headers head gaskets hybrid idle issue issues. lifters lq1 master cylinder older pistons poor mpg power steering propane pushrods question remote mount turbo roots seals seats shifter short block supercharged swap tags timing change top end swap tranny trans turbo w-body z24
By 3100 MPFI at 02/14/2008 - 19:36
One of the biggest problems with 60-degree engines not running properly tends to be the engine grounds getting dirty and losing proper contact.
While tracking down a problem with my 1990 Grand Prix STE (3.1 MPFI, and 440T4), I decided to go ahead and clean the 2 engine grounds.  The procedure for cleaning these 2 grounds is very similar to cleaning them on the 3100 SFI, and the 3.4 DOHC as well.
Of the 6 engine to transmission bellhousing bolts, the front 2 (directly over the starter) are used as the grounds.  Over time, grime, oil, transmission fluid and other nasty stuff builds up on them and can lead to problems.
Here is what they looked like on my 1990 Grand Prix STE before I cleaned them.  This is only the top one of the two, but as you can see, it is REALLY dirty, and the bottom one was worse.
To do this, I chose to remove some things to make access easier.  I removed the BATTERY CABLES, AIR CLEANER, DRIVERS SIDE TORQUE STRUT (DOGBONE) DRIVERS SIDE COOLING FAN, EXHAUST CROSSOVER, and THROTTLE DETENT CABLE (440T4, and early 4T60 only).  This gave me room to not only do the work, but to see what I was doing.
This is the ground with everything removed.  As you can see it is REALLY nasty under there.
I used a combination of ENGINE DEGREASER and CARB CLEANER to get the dirt off.  I sprayed on the degreaser, and would wait a few minutes, then spray more.  Once that can was empty, I used the carb cleaner to get the degreasers thick residue off.  In the end, I had some really clean mounting points.  I also used the carb cleaner to clean the ends of the wires.
Here are the clean mounting points.
I then reattached the wires to the clean points.
After everything was reattached, I reinstalled everything and tested it out.  Some of the minor issues that I had were fixed after cleaning them.
Search Forums
Advanced Search
Recent Threads
Latest poll
What is your current 87 octane gas price?
Less than $3.50
0
$3.50 to $3.75
4
$3.76 to $4.00
13
$4.01 to $4.25
6
More than $4.25
3
Who's online
There are currently 1 user and 20 guests online.
Online users
  • Joseph Upson
Powered by vBulletin® Version 3.7.0
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
© 2000-2008, 60DegreeV6.com
