Go Back   60DegreeV6.com > Pushrod > GEN 3/4 Maintenance > Timing Chain Repair
Search Content
Navigation
Motor Articles
In Depth Articles
Miscellaneous
Welcome to 60DegreeV6.com
Welcome to 60DegreeV6.com, the best source for all your GM 60º V6 needs.
If you have a question, please visit the forums and ask there. If you would like to add content to the site, visit the "Create Content" link on the navigation menu. We are always looking for people to add content to the site in order to further expand the site to continue to benefit the community.
Timing Chain Repair
REMOVAL AND INSTALLATION
[3100/3400 Engine]
This procedure requires the use of a crankshaft sprocket removal tool, and a sprocket installation tool.
Disassembly
  1. Bring the engine to TDC on #1 cylinder
  2. Disconnect the negative battery cable.
  3. Drain and recycle the engine coolant.
  4. Remove the right front tire and wheel.
  5. Remove the engine front cover, as outlined in this section.
  6. Align the timing marks on the cam and crank sprockets. Use the alignment marks on the damper stamping or the cast alignment marks on the cylinder and case for reference.
  7. Place the #1 piston at top dead center with the marks on the camshaft and crankshaft sprockets aligned.
  8. Unfasten the camshaft sprocket bolt, then remove the camshaft sprocket and chain.
  9. Lock the crankshaft to prevent it from turning, by freezing it with a prybar at the flywheel before attempting to remove the crank sprocket.
  10. Remove the crankshaft sprocket using a suitable sprocket removal tool.
Assembly
  1. Install the crankshaft sprocket with a suitable tool. Lubricate the sprocket thrust surface.
  2. Hold the camshaft sprocket with the chain hanging down and around the crank sprocket.
  3. Align the dowel in the camshaft with the dowel hole in the camshaft sprocket.
  4. Draw the camshaft sprocket onto the camshaft using the mounting bolts. Tighten to the specifications shown in the accompanying figure. Install the crank bolt.
  5. Lubricate the timing chain with engine oil.
  6. Unlock the flywheel and using a socket and breaker bar, rotate the engine (crankshaft) twice. Make sure the timing marks line up again at TDC.
  7. Install the engine front cover, using the directions given earlier in this section, and complete the installation procedure.
  8. Connect the negative battery cable.
Recent Threads
Stuff from our Store
Support this site by buying our stuff!
Powered by vBulletin® Version 3.8.2
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
© 2000-2010, 60DegreeV6.com
Page generated in 0.27122 seconds with 230 queries
