Register FAQ Members List Calendar Search Today's Posts Mark Forums Read
Go Back   60DegreeV6.com > OBD2 Inspection/Maintenance Procedure
Support the Site!
Like what you see here? Support the site to help us continue to grow.
Search Content
Navigation
Motor Articles
In Depth Articles
Miscellaneous
Stuff from our Store
Support this site by buying our stuff!
Welcome to 60DegreeV6.com
Welcome to 60DegreeV6.com, the best source for all your GM 60º V6 needs.
If you have a question, please visit the forums and ask there. If you would like to add content to the site, visit the "Create Content" link on the navigation menu. We are always looking for people to add content to the site in order to further expand the site to continue to benefit the community.
Forum Tag Cloud
2.8 hybrid 3.1l 3.4 3.4 camaro 1994 rwd 4t60 3100 3100 head porting 3400 3400 head porting 3500 3500 rods alternator automatic beretta performance boost boosted brad built burette camber centrifugal client compression convertible copper gaskets copper head gaskets corsica crank trigger csc dohc double roller eagle h-beam ecm electronic email engine fire fiero forged headers head gaskets hybrid idle issue issues. lifters lq1 master cylinder older pistons poor mpg power steering propane pushrods question remote mount turbo roots seals seats shifter short block supercharged swap tags timing change top end swap tranny trans turbo w-body z24
Inspection/Maintenance (I/M) Complete System Set Procedure
Description
The purpose of the I/M Complete System Set Procedure is to satisfy the enable criteria necessary to execute all of the I/M readiness diagnostics, and complete the trips for those particular diagnostics. When all diagnostic tests are completed, the I/M System Status indicators are set to YES. Perform this test when more than one or all of the I/M System Status indicators are set to NO.
Conditions for Running
Cold Start
  • The barometric pressure is more than 65 kPa.
  • The engine coolant temperature (ECT) is below 30ºC (86ºF).
  • The intake air temperature (IAT) is below 32ºC (90ºF).
  • The difference between the intake air temperature (IAT) and the engine coolant temperature (ECT) is 5ºC (7ºF) or less.
  • The battery voltage is between 10.0-18.0 volts.
  • The fuel level is between � and �.
    Diagnostic Aids
    Rough road conditions may prevent some of the tests from running. Extreme high or low ambient temperatures may prevent tests such as HO2S Heater and EVAP System from initiating. If a step is interrupted before completion, perform the remaining portion of the set procedures. Any portion of the set procedure that requires the engine at operating temperature may be repeated. This allows most of the diagnostics to run and the remaining tests can be performed using the individual System Set Procedures.
    If the vehicle has recently run, start this procedure at step 3. This will allow the tests that require the engine at operating temperature to run. Using this method allows shorter cool down periods if the tests requiring a cold start do not initiate.
    The scan tool can be used to monitor each of the I/M System Status indicators during the I/M Complete System Set Procedure. When all of the indicators for a test step have updated to YES, testing can move on to the next step even if the remaining portion of the test is not complete. For example, step 3 is designed to run the evaporative emission (EVAP), secondary air injection (AIR), and heated oxygen sensor (HO2S) tests. The procedure instructs the technician to operate the vehicle in the enable conditions for 6 minutes. If all 3 tests have updated to YES within 4 minutes, it is not necessary to continue with the enable conditions and testing can advance to the next step.
    Test Description
    The numbers below refer to the step numbers on the diagnostic table.
    Make sure you perform the I/M System Check before performing this test. Failure to do so may result in difficulty updating the status to YES.
    This step is to run the HO2S Heater Tests and initiate the EVAP System Test.
    Preprogramming the scan tool will reduce the amount of time the oxygen sensor heaters operate while verifying the enable criteria.
    The engine control module considers the engine to be cold if the following conditions are met:
  • ECT less than 30ºC (86ºF)
  • ECT and IAT are within 5ºC (7ºF) of each other at start up
    This step is to run the EVAP, AIR and the Oxygen Sensor Tests. The EVAP Test begins once the engine coolant reaches a calibrated temperature. The AIR Test, if equipped, begins shortly after Closed Loop and the indicated speed is achieved. The Oxygen Sensor Tests begin once the engine is at operating temperature, in Closed Loop Fuel Control, and a calibrated amount of time has elapsed.
    This step is to run the EGR Tests. The EGR Tests are run during a gradual deceleration with a closed throttle. The vehicle speed is required in order to maintain a high, steady manifold absolute pressure (MAP) signal.
    This step is to run the Catalyst Tests. This test runs during the idle period immediately following a cruise period that meets a minimum calibrated RPM and time period.
    Perform the individual system test for any of the systems that do not update to YES.
    The I/M System Status only reports on whether or not a diagnostic has run, not what the outcome of the test was. If any emission related DTC sets after the tests are complete, the DTC will require diagnosis.
    Step
    Action
    Value(s)
    Yes
    No
    1
    Did you perform the Inspection/Maintenance (I/M) System Check?
    Go to Step 2
    Go to Inspection/Maintenance (I/M) System Check
    2
    Important: Whenever the ignition is turned ON, ignition positive voltage is supplied to the HO2S heaters. After verifying the enable criteria, turn OFF the ignition for approximately 5 minutes to allow the sensors to cool before continuing with the test. Once the engine is started, DO NOT turn the engine OFF for the remaining portion of the set procedure.
    Preprogram the scan tool with the vehicle information before the ignition is turned ON.
    Ensure the vehicle is within the Conditions for Running specified in the supporting text.
    Turn OFF all of the accessories, e.g., A/C, blower fan, etc.
    Set the vehicle parking brake.
    Verify the transmission is in Park for automatic transmissions and Neutral for manual transmissions.
    Start the engine and allow it to idle.
    Allow the engine to idle for the specified time.
    Is the action complete?
    2 minutes
    Go to Step 3
    3
    Caution: Refer to Road Test Caution in Cautions and Notices.
    In order for the next group of tests to run, the vehicle must operate in the following conditions:
    Acceleration at part throttle to 90 km/h (55 mph) with this speed maintained until the engine reaches operating temperature. This may be up to 8-10 minutes depending on the start up coolant temperature.
    Continue operation under these conditions for an additional 6 minutes.
    Go to Step 4
    4
    Vehicle speed reduced to 72 km/h (45 mph) with this speed maintained for one additional minute.
    Four decelerations of 25 seconds each from 72 km/h (45 mph) while the following criteria is maintained:
    - Throttle is closed
    - NO brake application on either manual or automatic transmission
    - NO clutch actuation on a manual transmission
    - NO manual downshift
    - Vehicle speed remains above 40 km/h (25 mph)
    - After each deceleration period, vehicle is returned to 72 km/h (45 mph) under part throttle acceleration and speed is maintained for 15 seconds
    Go to Step 5
    5
    Acceleration at part throttle to 75-89 km/h (45-55 mph) with this speed maintained for 2 minutes.
    Deceleration to 0 km/h (0 mph).
    Engine idling for 2 minutes while the following criteria is maintained:
    - Service brake depressed
    - Automatic transmission in drive
    - Manual transmission in neutral with the clutch pedal depressed
    Go to Step 6
    6
    With a scan tool, observe the I/M System Status display.
    Did all of the I/M System Status indicators update to YES?
    Go to Step 7
    Go to the I/M System Set Procedure for the indicated systems
    7
    With a scan tool, observe the Emission Related DTC portion of the I/M System Status display.
    Does the scan tool indicate any Emission Related DTCs set?
    Go to Diagnostic Trouble Code (DTC) List
    System OK
    Search Forums
    Advanced Search
    Recent Threads
    Latest poll
    What is your current 87 octane gas price?
    Less than $3.50
    0
    $3.50 to $3.75
    4
    $3.76 to $4.00
    13
    $4.01 to $4.25
    6
    More than $4.25
    3
    Who's online
    There are currently 6 users and 33 guests online.
    Online users
    • Hawk58
    • tinknock
    • 923.4v6
    • 94GPGTP
    • AWeb80
    Powered by vBulletin® Version 3.7.0
    Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
    © 2000-2008, 60DegreeV6.com
