Register Arcade FAQ Community Calendar Today's Posts Search
Go Back   60DegreeV6.com > Pushrod > GEN 1/2 Performance > Connecting Rods
Search Content
Navigation
Motor Articles
In Depth Articles
Miscellaneous
Welcome to 60DegreeV6.com
Welcome to 60DegreeV6.com, the best source for all your GM 60º V6 needs.
If you have a question, please visit the forums and ask there. If you would like to add content to the site, visit the "Create Content" link on the navigation menu. We are always looking for people to add content to the site in order to further expand the site to continue to benefit the community.
Connecting Rods
Stock connectiong rods, part # 12515767
This forged steel connecting rod is used in all V6/60 Cevrolet engines. It has a 5.700" center to center length. Production rods are suitable for off-highway V6/60 engines which operate at a maximum engine speed of 7000 rpm. Use bolt P/N 466337 and nut P/N 361970.
350 V8 rods will also work, but require a little machining to work. The advantage to this is, the aftermarket for 350 V8s is huge, so you can find just about any spec rod you would like. They do however weigh more, so its something to consider for a light rebuild which won't exceed the stock rod spec. You can also shot-peen the rods to make the stronger. Polishing, cryo-treat, resize, and using ARP bolts are other possibilities to strengthen and make the rods work better.
To find out what needs to be done in order to fit these rods, check out these 2 pages from Chevrolet Power. There is also some crank and piston information as well.
ARP Rod bolts are also a good idea. Stock rods take Kit - 133-6002. You can find these in the 60V6 store.
by 60dgrzbelow0 on Mon, 07/06/2009 - 21:40
Excellent Tech Subject and POST!
This video might add to the visual side of the subject:
http://www.youtube.com/watch?v=hp931tDlHoU
by no_doz on Thu, 07/09/2009 - 02:01
i just learn-ed :P so if i get aftermarket rods im going steel h-beam all the way!!
Recent Threads
Stuff from our Store
Support this site by buying our stuff!
Powered by vBulletin® Version 3.8.2
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
© 2000-2010, 60DegreeV6.com
Page generated in 0.39278 seconds with 250 queries
