Go Back   60DegreeV6.com > Specifications > 3900 Engine Specifications
Search Content
Navigation
Motor Articles
In Depth Articles
Miscellaneous
Welcome to 60DegreeV6.com
Welcome to 60DegreeV6.com, the best source for all your GM 60º V6 needs.
If you have a question, please visit the forums and ask there. If you would like to add content to the site, visit the "Create Content" link on the navigation menu. We are always looking for people to add content to the site in order to further expand the site to continue to benefit the community.
3900 Engine Mechanical Specifications
Application
Specification
Metric English
General Data
Engine Type 60 degree V-6
Displacement 3.9L 238 cu in
RPO LZ9
VIN 1
Bore 99 mm 3.90 in
Stroke 84 mm 3.31 in
Compression
Ratio
9.8:1
Firing Order 123456
Spark Plug
Gap
1.00 mm 0.040 in
Block
Camshaft
Bearing Bore Diameter - Front and Rear
55.26-55.31 mm
2.175-2.177 in
Camshaft
Bearing Bore Diameter - Middle #2, #3
54.75-54.80 mm
2.155-2.157 in
Crankshaft
Main Bearing Bore Diameter
72.1535-72.0695 mm
2.840-2.841 in
Crankshaft Main Bearing
Bore Out-of-Round
0.008 mm 0.00031 in
Cylinder Bore Diameter
99.000-99.018 mm
3.897-3.898 in
Cylinder Bore
Out-of-Round - Diameter - Production
0.026 mm 0.0010 in
Cylinder Bore
Out-of-Round - Diameter - Service
0.030 mm 0.0011 in
Cylinder Bore
Taper - Production
0.026 mm 0.0010 in
Cylinder Bore
Taper - Service
0.030 mm 0.0011 in
Cylinder Head Deck Height 224 mm 8.818 in
Cylinder Head Deck
Surface Flatness
0.05 mm
per 150 mm
0.0019 in
per 5.905 in
Valve Lifter Bore
Diameter
21.417-21.455 mm
0.843-0.844 in
Camshaft
Camshaft
Bearing Inside Diameter
51.500-51.525 mm
2.028-2.029 in
Camshaft
Journal Diameter
51.415-51.440 mm
2.024-2.025 in
Camshaft
Journal Out-of-Round
0.025 mm 0.001 in
Camshaft
Lobe Lift - Exhaust
6.9263 mm 0.2727 in
Camshaft
Lobe Lift - Intake
6.9263 mm 0.2727 in
Cooling System
Thermostat
Full Open Temperature
195 degrees
Connecting Rod
Connecting
Rod Bearing Clearance
0.018-0.062 mm
0.0007-0.0024 in
Connecting
Rod Bore Diameter
60.322-60.338 mm
2.375-2.376 in
Connecting
Rod Bore Out-of-Round
0.006 mm 0.00023 in
Connecting
Rod Length - Center to Center
150 mm 5.9 in
Connecting
Rod Side Clearance
0.200-0.241 mm
0.008-0.009 in
Crankshaft
Connecting
Rod Journal Diameter
57.122-57.138 mm
2.248-2.249 in
Connecting
Rod Journal Out-of-Round
0.005 mm 0.0002 in
Connecting
Rod Journal Taper
0.005 mm 0.0002 in
Connecting Rod Journal
Width
21.92-22.08 mm
0.863-0.869 in
Crankshaft End Play
0.060-0.210 mm
0.0024-0.0083 in
Clearance - Except #3
0.019-0.064 mm
0.0008-0.0025 in
Clearance - #3 Thrust Bearing
0.032-0.077 mm
0.0012-0.0030 in
Crankshaft Main Journal
Out-of-Round
0.005 mm 0.0002 in
Taper
0.005 mm 0.0002 in
Crankshaft Rear Flange
Runout
0.04 mm 0.0016 in
Cylinder Head
Combustion
Chamber Depth - at Measurement Point
2.2 mm 0.087 in
Surface
Finish - Maximum
2.8 RA
Surface
Flatness - Block Deck
0.08 mm
per 152 mm
0.003 in
per 6 in
Surface
Flatness - Exhaust Manifold Deck
0.1 mm 0.004 in
Surface
Flatness - Intake Manifold Deck
0.1 mm 0.004 in
Valve Guide
Bore - Exhaust
8.01 mm 0.315 in
Valve Guide
Bore - Intake
8.01 mm 0.315 in
Valve Guide
Installed Height
16.6 mm 0.654 in
Lubrication System
Oil Capacity
- with Filte
3.8 liter 4.0 quarts
Oil Pressure
- @ 1850 RPM
207-310 kPa 30-45 PSI
Oil Pump
Gear
Diameter
38.05-38.10 mm
1.498-1.500 in
Gear Pocket
- Dept
30.52-30.58 mm
1.202-1.204 in
Gear Pocket
- Diameter
38.176-38.226 mm
1.503-1.505 in
Gears Lash
0.094-0.195 mm
0.0037-0.0077 in
Relief
Valve-to-Bore Clearance
0.038-0.089 mm
0.0015-0.0035 in
Pin
Piston Pin Clearance to
Connecting Rod Bore - Press Fit
-0.004 to -0.021 mm
-0.0001 to -0.0008 in
Piston Pin Bore
0.002-0.010 mm
0.00008-0.0004 in
Piston Pin Diameter
23.952-23.955 mm
0.942-0.943 in
Piston Pin Length
64.21-64.44 mm
2.57-2.53 in
Piston
Piston Diameter -
Production
98.970-99.008 mm
3.896-3.897 in
Piston Diameter - Service
Limit
98.950 mm 3.895 in
Piston Pin Bore Diameter
23.957-23.962 mm
0.943 in
Piston Ring Groove Width
1.22-1.24 mm
0.048-0.049 in
Piston to Bore Clearance
- Production
-0.008 to +0.048 mm
-0.0003 to +0.0018 in
Piston to Bore
Clearance - Service Limit - Maximum
0.080 mm 0.003 in
Piston Ring
End Gap
First
Compression Ring
0.15-0.30 mm
0.006-0.011 in
Second
Compression Ring
0.25-0.45 mm
0.009-0.017 in
Oil Control
Ring
0.15-0.65 mm
0.06-0.025 in
Piston Ring to Groove Clearance
First
Compression Ring
0.03-0.065 mm
0.001-0.002 in
Second
Compression Ring
0.02-0.055 mm
0.0007-0.002 in
Oil Control
Ring
0.01 mm 0.004 in
Piston Ring Thickness
First
Compression Ring
1.175-1.190 mm
0.046-0.047 in
Second
Compression Ring
1.475-1.490 mm
0.058 in
Oil Control
Ring - Maximum
2.50 mm 0.098 in
Valves
Valve Face
Angle
45 degrees
Valve Seat
Angle
46 degrees
Valve Seat
Depth - Exhaust - From Deck Face
8.9-9.1 mm
0.350-0.358 in
Valve Seat
Depth - Intake - From Deck Face
7.9-8.1 mm
0.311-0.318 in
Valve Seat Width -
Exhaust
1.70-2.0 mm
0.067-0.079 in
Valve Seat Width - Intake
1.55-1.80 mm
0.061-0.071 in
Valve Stem-to-Guide
Clearance
0.026-0.068 mm
0.0010-0.0027 in
Valve
Lifters/Push Rods
Push Rod Length - Intake 146.0 mm 5.75 in
Push Rod Length - Exhaust 152.5 mm 6.0 in
Valve Springs
Valve Spring Free Length 48.5 mm 1.89 in
Valve Spring Installed
Height
43.2 mm 1.701 in
Valve Spring Load -
Closed
320 N
43.2 mm
75 lb
1.701 in
Valve Spring Load - Open 1036 N
32 mm
230 lb 1.260 in
Valve Spring Total Number
of Coils
6.55
Fastener Tightening Specifications
Application
Specification
Metric English
Camshaft Position Sensor
Bolt
10 N·m 89 lb in
Camshaft
Sprocket Bolt
140 N·m 103 lb ft
Camshaft
Thrust Plate Screw
10 N·m 89 lb in
Connecting Rod Bearing Cap Bolt
  • First Pass
25 N·m 18 lb ft
  • Final Pass
110 degrees
Coolant
Drain Plug
19 N·m 14 lb ft
Coolant
Temperature Sensor
23 N·m 17 lb ft
Crankshaft
Balancer Bolt
160 N·m 118 lb ft
Crankshaft Main Bearing Cap Bolt/Stud
  • First Pass
50 N·m 37 lb ft
  • Final Pass
77 degrees
Crankshaft
Oil Deflector Nut
25 N·m 18 lb ft
Crankshaft
Position Sensor Stud - Side of Engine Block
10 N·m 89 lb in
Cylinder Head Bolt
  • First Pass
60 N·m 44 lb ft
  • Final Pass
95 degrees
Cylinder Head Plug 20 N·m 15 lb ft
Drive Belt
Tensioner Bolt
50 N·m 37 lb ft
EGR Valve Assembly Bolt 30 N·m 22 lb ft
EGR Valve Pipe Bolt - EGR 25 N·m 18 lb ft
EGR Valve Pipe
Bolt - Exhaust Manifold
30 N·m 22 lb ft
Engine Front Cover Bolt
  • Large Bolt
55 N·m 41 lb ft
  • Medium Bolt
55 N·m 41 lb ft
  • Small Bolt
27 N·m 20 lb ft
Engine Mount
Strut and A/C Compressor Bracket Bolt
50 N·m 37 lb ft
Engine Mount Strut and
Generator Bracket Bolt
50 N·m 37 lb ft
Engine Mount
Strut and Lift Bracket Bolt - Engine Lift Rear
50 N·m 37 lb ft
Engine Mount
Strut and Support Bracket Bolt
25 N·m 18 lb ft
Engine Oil
Pressure Indicator Switch
16 N·m 12 lb ft
Engine
Wiring Harness Bracket Bolt
13 N·m 115 lb in
EVAP Purge Valve Bolt 10 N·m 89 lb in
Exhaust
Manifold Heat Shield Bolt
10 N·m 89 lb in
Exhaust
Manifold Nut
16 N·m 12 lb ft
Exhaust
Manifold Stud
18 N·m 13 lb ft
Flywheel
Bolt
70 N·m 52 lb ft
Front Oil Gallery
Plug - Small
19 N·m 14 lb ft
Front Oil Gallery
Plug - Large
33 N·m 24 lb ft
Fuel Feed
Pipe to Fuel Injector Rail Bolt
10 N·m 89 lb in
Fuel
Injector Rail Bolt
10 N·m 89 lb in
Heated
Oxygen Sensor
42 N·m 31 lb ft
Heater Inlet
Pipe Nut
25 N·m 18 lb ft
Heater Inlet
Pipe Stud
35 N·m 26 lb ft
Ignition
Coil Bracket Bolt/Nut/Stud
25 N·m 18 lb ft
Intake
Manifold Coolant Pipe Bolt
10 N·m 89 lb in
Knock Sensor 25 N·m 18 lb ft
Lower Intake
Manifold Bolt - Center
20 N·m 15 lb ft
Lower Intake Manifold
Bolt - Corner
25 N·m 18 lb ft
MAP Sensor
Bolt
10 N·m 89 lb in
Oil Filter 30 N·m 22 lb ft
Oil Filter
Adapter Bolt
25 N·m 18 lb ft
Oil Filter
Bypass Hole Plug
19 N·m 14 lb ft
Oil Filter
Fitting
39 N·m 29 lb ft
Oil Level
Indicator Tube Bolt
25 N·m 18 lb ft
Oil Pan Bolt 25 N·m 18 lb ft
Oil Pan
Drain Plug
25 N·m 18 lb ft
Oil Pan Side
Bolt
50 N·m 37 lb ft
Oil Pump
Cover Bolt
10 N·m 89 lb in
Oil Pump
Drive Clamp Bolt
36 N·m 27 lb ft
Oil Pump
Mounting Bolt
41 N·m 30 lb ft
PCV Tube Clip bolt - Foul
Air
10 N·m 89 lb in
Piston Oil Nozzle Bolt 10 N·m 89 lb in
Rear Oil Gallery
Plug - 1/4 inch
19 N·m 14 lb ft
Rear Oil Gallery
Plug - 3/8 inch
33 N·m 24 lb ft
Spark Plug 15 N·m 11 lb ft
Thermostat
Bypass Pipe to Engine Front Cover Bolt
10 N·m 89 lb in
Thermostat
Bypass Pipe to Throttle Body Nut/Bolt
10 N·m 89 lb in
Throttle
Body Bolt
10 N·m 89 lb in
Throttle Body Stud 6 N·m 53 lb in
Timing Chain
Dampener Bolt
21 N·m 15 lb ft
Upper Intake
Manifold Bolt/Stud
25 N·m 18 lb ft
Valve Lifter
Guide Bolt
10 N·m 89 lb in
Valve Rocker
Arm Bolt
32 N·m 24 lb ft
Valve Rocker
Arm Cover Bolt
10 N·m 89 lb in
Water Outlet
Bolt
25 N·m 18 lb ft
Water Pump
Bolt
10 N·m 89 lb in
Water Pump
Pulley Bolt
25 N·m 18 lb ft
Recent Threads
Stuff from our Store
Support this site by buying our stuff!
Powered by vBulletin® Version 3.8.2
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
© 2000-2010, 60DegreeV6.com
Page generated in 0.30935 seconds with 244 queries
