Register Arcade FAQ Community Calendar Today's Posts Search
Go Back   60DegreeV6.com > Specifications > 3500 Engine Specifications
Search Content
Navigation
Motor Articles
In Depth Articles
Miscellaneous
Welcome to 60DegreeV6.com
Welcome to 60DegreeV6.com, the best source for all your GM 60º V6 needs.
If you have a question, please visit the forums and ask there. If you would like to add content to the site, visit the "Create Content" link on the navigation menu. We are always looking for people to add content to the site in order to further expand the site to continue to benefit the community.
3500 Engine Mechanical Specifications
Application
Specification
Metric
English
General Data
Engine Type
60 degree
V-6
Displacement
3.5L
214 cu in
RPO
LX9
VIN
8
Bore
94 mm
3.70 in
Stroke
84 mm
3.31 in
Deck Height
224 mm
8.818 in
Compression Ratio
9.8:1
Firing Order
123456
Spark Plug Gap
1.52 mm
0.060 in
Block
Camshaft Bearing Bore Diameter - Front and Rear
51.03-51.08 mm
2.009-2.011 in
Camshaft Bearing Bore Diameter - Middle #2, #3
50.77-50.82 mm
1.999-2.001 in
Crankshaft Main Bearing Bore Diameter
72.1535-72.1695 mm
2.840-2.841 in
Crankshaft Main Bearing Bore Out-of-Round
0.008 mm
0.00031 in
Cylinder Bore Diameter
93.991-94.009 mm
3.700-3.701 in
Cylinder Bore Out-of-Round - Diameter - Production
0.020 mm
0.0008 in
Cylinder Bore Out-of-Round - Diameter - Service
0.025 mm
0.001 in
Cylinder Bore Taper - Production
0.020 mm
0.0008 in
Cylinder Bore Taper - Service
0.025 mm
0.001 in
Cylinder Head Deck Height
224 mm
8.818 in
Cylinder Head Deck Surface Flatness
0.05 mm per 152 mm
0.0019 in per 6 in
Valve Lifter Bore Diameter
21.417-21.455 mm
0.843-0.844 in
Camshaft
Camshaft Bearing Inside Diameter
47.516-47.541 mm
1.871-1.872 in
Camshaft Journal Diameter
47.443-47.468 mm
1.868-1.869 in
Camshaft Journal Out-of-Round
0.025 mm
0.001 in
Camshaft Lobe Lift - Exhaust
6.9263 mm
0.2727 in
Camshaft Lobe Lift - Intake
6.9263 mm
0.2727 in
Cooling
System
Capacity
12.4 liters
13.1 quarts
Thermostat Full Open Temperature
195 degrees
Connecting
Rod
Connecting Rod Bearing Clearance
0.18-0.062 mm
0.0007-0.017 in
Connecting Rod Bore Diameter
60.322-60.338 mm
2.375-2.376 in
Connecting Rod Bore Out-of-Round
0.006 mm
0.00023 in
Connecting Rod Length - Center to Center
150 mm
5.9 in
Connecting Rod Side Clearance
0.200-0.241 mm
0.008-0.009 in
Connecting Rod Journal Diameter
57.122-57.138 mm
2.249-2.250 in
Crankshaft
57.122-57.138 mm
2.248-2.249 in
Connecting Rod Journal Out-of-Round
0.005 mm
0.0002 in
Connecting Rod Journal Taper
0.008 mm
0.0003 in
Connecting Rod Journal Width
21.92-22.08 mm
0.863-0.869 in
Crankshaft End Play
0.060-0.210 mm
0.0024-0.0083 in
Crankshaft Main Bearing Journal Width
23.9-24.1 mm
0.941-0.949 in
Crankshaft Main Bearing Clearance
0.019-0.064 mm
0.0008-0.0025 in
Crankshaft Main Journal Diameter
67.239-67.257 mm
2.6473-2.6483 in
Crankshaft Main Journal Out-of-Round
0.005 mm
0.0002 in
Crankshaft Main Journal Taper
0.008 mm
0.0003 in
Crankshaft Rear Flange Runout
0.04 mm
0.0016 in
Cylinder
Head
Combustion Chamber Depth - at Measurement Point
2.2 mm
0.087 in
Surface Finish - Maximum
2.8 RA
Surface Flatness - Block Deck
0.08 mm Per 152 mm
0.003 in Per 6 in
Surface Flatness - Exhaust Manifold Deck
0.1 mm
0.004 in
Surface Flatness - Intake Manifold Deck
0.1 mm
0.004 in
Valve Guide Bore - Exhaust
8.01 mm
0.315 in
Valve Guide Bore - Intake
8.01 mm
0.315 in
Valve Guide Installed Height
16.6 mm
0.654 in
Lubrication
System
Oil Capacity - with Filter
3.8 liter
4.0 quarts
Oil Capacity - without Filter
3.3 liter
3.5 quarts
Oil Pressure - @ 1850 RPM
207-310 kPa
30-45 PSI
Oil Pump
Gear Diameter
38.05-38.10 mm
1.498-1.500 in
Gear Pocket - Depth
30.53-30.59 mm
1.202-1.204 in
Gear Pocket - Diameter
38.176-38.226 mm
1.503-1.505 in
Gears Lash
0.094-0.195 mm
0.0037-0.0077 in
Relief Valve-to-Bore Clearance
0.038-0.089 mm
0.0015-0.0035 in
Piston Ring End Gap
First Compression Ring
0.18-0.39 mm
0.007-0.015 in
Second Compression Ring
0.48-0.74 mm
0.019-0.029 in
Oil Control Ring
0.25-0.74 mm
0.010-0.029 in
Piston Ring
to Groove Clearance
0.03-0.076 mm
0.001-0.003 in
0.04-0.078 mm
0.002-0.003 in
Oil Control Ring
0.09 mm
0.004 in
Piston Ring
Thickness
1.164-1.190 mm
0.046-0.047 in
1.472-1.490 mm
0.058 in
Oil Control Ring - Maximum
2.440 mm
0.096 in
Piston
Piston Diameter - production
93.980-94.020 mm
3.7-3.701 in
Piston Diameter - service limit
93.960 mm
3.699 in
Piston Pin Bore Diameter
24.008-24.013 mm
0.9452-0.9454 in
Piston Ring Groove Width
1.23-1.255 mm
0.048-0.049 in
Piston to Bore Clearance - production
-0.029 to +0.029 mm
-0.0011 to +0.011 in
Piston to Bore Clearance - service limit - Maximum
0.080 mm
0.003 in
Pin
Piston Pin Clearance to Connecting Rod Bore - Press
Fit
-0.022 to +0.044 mm
-0.0008 to +0.0017 in
Piston Pin Clearance to Piston Pin Bore
0.008-0.016 mm
0.0003-0.0006 in
Piston Pin Diameter
23.997-24.000 mm
0.9447-0.9448 in
Piston Pin Length
59.87-60.13 mm
2.35-2.36 in
Valves
Valve Face Angle
45 degrees
Valve Seat Angle
46 degrees
Valve Seat Depth - Intake - from deck face
7.9-8.1 mm
0.311-0.318 in
Valve Seat Depth - Exhaust - from deck face
8.9-9.1 mm
0.350-0.358 in
Valve Seat Width - Intake
1.55-1.80 mm
0.061-0.071 in
Valve Seat Width - Exhaust
1.70-2.0 mm
0.067-0.079 in
Valve Stem-to-Guide Clearance
0.026-0.068 mm
0.0010-0.0027 in
Valve Lifters/Push Rods
Push Rod Length - Intake
144.2 mm
5.67 in
Push Rod Length - Exhaust
152.5 mm
6.0 in
Valve Springs
Valve Spring Free Length
50.0 mm
1.91 in
Valve Spring Installed Height
44.2 mm
1.74 in
Valve Spring Load - Closed
343 N [commat]44.2 mm
77 lb 1.74 in
Valve Spring Load - Open
1041 N [commat]33 mm
234 lb 1.299 in
Valve Spring Total Number of Coils
7.10
Cylinder Head CC
32.46cc
Piston CC
24.5cc
Head Gasket Bore
3.800"
Head Gasket Thickness
.060"
Piston Deck Height
-.020"
Fastener Tightening Specifications
Application
Specification
Metric
English
Camshaft Position Sensor
Bolt
10 N·m
89 lb in
Camshaft Sprocket Bolt
140 N·m
103 lb ft
Camshaft Thrust Plate
Screw
10 N·m
89 lb in
Connecting
Rod Bearing Cap Bolt
  • First Pass
25 N·m
18 lb ft
  • Final Pass
110 degrees
Coolant Drain Plug
19 N·m
14 lb ft
Coolant Temperature
Sensor
23 N·m
17 lb ft
Crankshaft
Balancer Bolt
  • First Pass
70 N·m
52 lb ft
  • Final Pass
70 degrees
Crankshaft
Main Bearing Cap Bolt/Stud
  • First Pass
50 N·m
37 lb ft
  • Final Pass
77 degrees
Crankshaft Oil Deflector
Nut
25 N·m
18 lb ft
Crankshaft Position
Sensor Stud - Side of Engine Block
10 N·m
89 lb in
Cylinder
Head Bolt
  • First Pass
60 N·m
44 lb ft
  • Final Pass
95 degrees
Drive Belt Tensioner
Bolt
50 N·m
37 lb ft
EGR Valve Assembly Bolt
30 N·m
22 lb ft
EGR Valve Pipe Bolt - Exhaust
Manifold
30 N·m
22 lb ft
EGR Valve Pipe
Bolt - EGR
25 N·m
18 lb ft
Engine Front
Cover Bolt
  • Large Bolt
55 N·m
41 lb ft
  • Medium Bolt
55 N·m
41 lb ft
  • Small Bolt
27 N·m
20 lb ft
Engine Mount Strut and
A/C Compressor Bracket Bolt
50 N·m
37 lb ft
Lift Bracket Bolt - Engine Lift Rear
50 N·m
37 lb ft
Generator Bracket Bolt
50 N·m
37 lb ft
Support Bracket Bolt
25 N·m
18 lb ft
Engine Oil Pressure
Indicator Switch
16 N·m
12 lb ft
Engine Wiring Harness
Bracket Bolt
13 N·m
115 lb in
EVAP Purge Valve Bolt
10 N·m
89 lb in
Exhaust Manifold Heat
Shield Bolt
10 N·m
89 lb in
Exhaust Manifold Nut
16 N·m
12 lb ft
Exhaust Manifold Stud
18 N·m
13 lb ft
Flywheel Bolt
70 N·m
52 lb ft
Front Oil Gallery Plug - Small
19 N·m
14 lb ft
Front Oil Gallery Plug - Large
33 N·m
24 lb ft
Fuel Feed Pipe to Fuel
Injector Rail Bolt
10 N·m
89 lb in
Fuel Injector Rail Bolt
10 N·m
89 lb in
Heated Oxygen Sensor
42 N·m
31 lb ft
Heater Inlet Pipe Nut
25 N·m
18 lb ft
Heater Inlet Pipe Stud
35 N·m
26 lb ft
Ignition Coil Bracket
Bolt/Nut/Stud
25 N·m
18 lb ft
Intake Manifold Coolant
Pipe Bolt
10 N·m
89 lb in
Knock Sensor
25 N·m
18 lb ft
Lower Intake
Manifold Bolt - Center
  • First Pass
13 N·m
115 lb in
  • Final Pass
20 N·m
15 lb ft
Lower Intake Manifold
Bolt - Corner
  • First Pass
13 N·m
115 lb in
  • Final Pass
25 N·m
18 lb ft
MAP Sensor Bolt
10 N·m
89 lb in
Oil Filter Adapter Bolt
25 N·m
18 lb ft
Oil Filter
30 N·m
22 lb ft
Oil Filter Bypass Hole
Plug
19 N·m
14 lb ft
Oil Filter Fitting
39 N·m
29 lb ft
Oil Level Indicator Tube
Bolt
25 N·m
18 lb ft
Oil Pan Bolt
25 N·m
18 lb ft
Oil Pan Drain Plug
25 N·m
18 lb ft
Oil Pan Side Bolt
50 N·m
37 lb ft
Oil Pump Cover Bolt
10 N·m
89 lb in
Oil Pump Drive Clamp
Bolt
36 N·m
27 lb ft
Oil Pump Mounting Bolt
41 N·m
30 lb ft
PCV Tube Clip bolt - Foul Air
10 N·m
89 lb in
Piston Oil Nozzle Bolt
10 N·m
89 lb in
Rear Oil Gallery Plug - 1/4 inch
19 N·m
14 lb ft
Rear Oil Gallery Plug - 3/8 inch
33 N·m
24 lb ft
Spark Plug - Initial
Installation
20 N·m
15 lb ft
Spark Plug - After
Initial Installation
15 N·m
11 lb ft
Thermostat Bypass Pipe
to Engine Front Cover Bolt
10 N·m
89 lb in
to Throttle Body Nut/Bolt
10 N·m
89 lb in
Throttle Body Bolt
10 N·m
89 lb in
Throttle Body Stud
6 N·m
53 lb in
Timing Chain Dampener
Bolt
21 N·m
15 lb ft
Upper Intake Manifold
Bolt/Stud
25 N·m
18 lb ft
Valve Lifter Guide Bolt
10 N·m
89 lb in
Valve Rocker Arm Bolt
32 N·m
24 lb ft
Valve Rocker Arm Cover
Bolt
10 N·m
89 lb in
Water Outlet Bolt
25 N·m
18 lb ft
Water Pump Bolt
10 N·m
89 lb in
Water Pump Pulley Bolt
25 N·m
18 lb ft
Recent Threads
Stuff from our Store
Support this site by buying our stuff!
Powered by vBulletin® Version 3.8.2
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
© 2000-2010, 60DegreeV6.com
Page generated in 0.32952 seconds with 271 queries
