Register Arcade FAQ Community Calendar Today's Posts Search
Go Back   60DegreeV6.com > Specifications > 3.4L (DOHC) Engine Specifications
Search Content
Navigation
Motor Articles
In Depth Articles
Miscellaneous
Welcome to 60DegreeV6.com
Welcome to 60DegreeV6.com, the best source for all your GM 60º V6 needs.
If you have a question, please visit the forums and ask there. If you would like to add content to the site, visit the "Create Content" link on the navigation menu. We are always looking for people to add content to the site in order to further expand the site to continue to benefit the community.
3.4L (DOHC) Engine Mechanical Specifications
Application
Millimeters
Inches
General Data
Engine Type
60° V-6
Displacement
204 Cu In
Liter (VIN)
3.4 (X)
RPO
LQ1
Bore
92
3.622
Stroke
84
3.307
Deck Height
224
8.818
Compression Ratio
9.50:1
Firing Order
1-2-3-4-5-6
Oil Pressure @ Operating Temperature
103 kPa @ 1100 RPM
15 psi min @ 1100 RPM
Cylinder Bore
Diameter
92.020-92.038
3.6228-3.6235
Out Of Round Maximum
0.010
0.0004
Taper -- Thrust Side Maximum
0.013
0.00051
Center Distance
111.76
4.4
Piston
Diameter-gauged at skirt 10.44 mm
(0.413 in) below centerline of piston pin bore
91.985-92.000
3.6215-3.6220
Clearance
0.020-0.052
0.0008-0.0020
Pin Bore
23.003-23.010
0.9056-0.9059
Piston Ring
Compression Groove Clearance 1st and 2nd
0.033-0.079
0.0013-0.0031
Gap (at gauge diameter) 1st
0.20-0.45
0.008-0.018
Gap (at gauge diameter) 2nd
0.56-0.81
0.022-0.032
Oil Groove Clearance
0.028-0.206
0.0011-0.0081
Gap (segment at gauge diameter)
0.25-0.76
0.0098-0.0299
Tension 1st
27.6 N
6.2 lbs
Tension 2nd
19.8 N
4.5 lbs
Tension Oil
31.2 N
7.0 lbs
Piston Pin
Diameter
22.9915-22.9964
0.9052-0.9054
Clearance
0.0066-0.0185
0.00026-0.00073
Fit In Rod
0.0165-0.0464
0.0006-0.0018
Crankshaft
Main Journal Diameter-All
67.239-67.257
2.6472-2.6479
Taper-Maximum
0.005
0.0002
Out Of Round-Maximum
0.005
0.0002
Cylinder Block Main Bearing Bore Diameter
72.155-72.168
2.8407-2.8412
Crankshaft Main Bearing Inner Diameter
67.289-67.316
2.6492-2.6502
Main Bearing Clearance
0.019-0.064
0.0008-0.0025
Main Thrust Bearing Clearance
0.032-0.077
0.0013-0.0030
Crankshaft End Play
0.06-0.21
0.002-0.008
Crankpin
Diameter
50.768-50.784
1.9987-1.9994
Taper-Maximum
0.005
0.0002
0.005
0.0002
Rod Bearing Bore Diameter
53.962-53.984
2.124-2.125
Rod Inner Bearing Diameter
50.812-50.850
2.000-2.002
Rod Bearing Clearance
0.018-0.062
0.0007-0.0024
Rod Side Clearance
0.18-0.44
0.0071-0.0173
Camshaft
Lobe Lift (Intake)
9.398 @ 108° Crank ATDC
0.370 @ 108° Crank ATDC
Lobe Lift (Exhaust)
9.389 @ 115° Crank BTDC
0.370 @ 115° Crank BTDC
Timing Reference Set Position with Camshaft
Timing Flats in Clamped Position-Right Bank
TDC-1Piston Exhaust Stroke +/- 2° of Crankshaft
Timing Flats in Clamped Position-Left Bank
TDC-4 Piston Exhaust Stroke +/- 2° of Crankshaft
Journal Diameter
54.973-55.001
2.1643-2.1654
Bore Inside Diameter
55.050-55.075
2.1673-2.1683
Journal Clearance
0.049-0.102
0.0019-0.0040
Valve System
Lifter
Hydraulic
Face Angle
45°
Seat Angle
46°
Seat Runout-Maximum
0.075
0.0030
Seat Width Intake
1.25-1.50
0.0492-0.0591
Exhaust
1.60-1.90
0.063-0.0748
Valve Margin-Minimum
0.75
0.029
Stem Clearance Intake
0.028-0.066
0.0011-0.0026
Stem Clearance Exhaust
0.046-0.084
0.0018-0.0033
Valve Spring
Free Length
42.04
1.6551
Load (Closed)-All
289 N @ 35.56
65 lb @ 1.400
Load (Open)-All
711 N @ 26.16
160 lb @ 1.030
Approximate Number of Active Coils
4
Oil Pump
Valve to Bore Clearance
0.038-0.089
0.0015-0.0035
Gear Lash
0.094-0.195
0.0037-0.0077
Gear Pocket Depth
30.53-30.61
1.202-1.205
Diameter
38.202-38.252
1.504-1.506
Gear Length
30.45-30.48
1.199-1.20
Diameter
38.05-38.10
1.498-1.50
Side Clearance
0.08-0.10
0.003-0.004
End Clearance
0.05-0.152
0.002-0.006
3.4L (DOHC) Fastener Tightening Specifications
Application
N·m
Lb Ft
Lb In
Accelerator Control Cable Bracket Bolt
10
89
Accelerator Control Cable Bracket Nut
10
89
Camshaft Carrier Cover Bolt
11
97
Camshaft Carrier Thrust Plate Bolt
10
89
Camshaft Carrier Thrust Plate Cover Bolt
10
89
Camshaft Drive Belt Cover Bolt
10
89
Camshaft Drive Sprocket Bolt
130
96
Camshaft Housing Assembly Bolt
27
20
Camshaft Position Sensor Bolt
50
37
Connecting Rod Cap Nut
20 +75°
15 +75°
Coolant By-Pass Nut
25
18
Coolant Inlet Housing Bolt
25
18
Coolant Outlet Bolt
27
20
Coolant Pump Bolt
11
97
Coolant Pump Pulley Bolt
25
18
Crankshaft Balancer Mounting Bolt
107
79
Crankshaft Main Bearing Cap Bolt
50+75°
37+75°
Crankshaft Main Bearing Cap Stud
50+75°
37+75°
Crankshaft Oil Deflector Nut
25
18
Crankshaft Pulley-to-Crankshaft Damper Bolt
60
44
Crankshaft Position Sensor Bolt-Front of
Engine
8
71
Crankshaft Position Sensor Bolt-Side of Engine
8
71
Crankshaft Position Sensor Harness Retaining
Bracket Bolt
5
45
Cylinder Head Bolt
60 +90°
44 +90°
Drive Belt Tensioner Bolt
50
37
EGR Valve Adapter Brace Nut
25
18
EGR Valve Adapter Stud
10
89
EGR Tube Assembly
25
18
EGR Valve Assembly Nut
25
18
Electronic Ignition Control Module Assemble
Bolt/Stud
25
18
Electronic Ignition Control Assembly Nut
25
18
Engine Block Coolant Drain Plug
19
14
Engine Block Oil Gallery Plug-Center Rear
16
12
Engine Block Oil Gallery Plug-Rear
33
24
Engine Block Oil Gallery Plug-Side of Block
19
14
Engine Coolant Temperature Sensor
18
13
Engine Motor Mount Frame Nut-Engine Left Side
43
32
Engine Motor Mount Bracket Nut-Engine Left
Side
43
32
Engine Motor Mount Frame Nut-Engine Right Side
43
32
Engine Motor Mount Bracket Nut-Engine Right
Side
47
35
Engine Motor Mount Bracket -Front of Block
Bolt-Engine Left Side
103
76
Engine Motor Mount Bracket-Side of Block
Bolts-Engine Left Side
58
43
Engine Motor Mount Bracket-Front of Block
Bolts-Engine Right Side
102
75
Bolt-Engine Right Side
58
43
Engine Motor Mount Bracket-Transaxle
75
55
Engine Mount Strut Bracket Bolt
80
59
Engine Oil Cooler Connector
40
30
Engine Oil Level Sensor
22
16
Evaporator Emission Canister Purge Solenoid
Mounting Bracket Bolt
10
89
Exhaust Manifold Crossover Stud
9
80
Exhaust Manifold Nut
13
116
Exhaust Manifold Stud
17
13
Flywheel Bolt
82
60
Front Cover Coolant Drain Plug
25
18
Front Cover Bolts- Large
47
35
Front Cover Bolts - Small
27
20
Front Cover-to-Front Engine Lift Hook Bolt
25
18
Front Engine Lift Hook-to-Right Camshaft
Carrier Bolt
50
37
Front Engine Lift Hook-to-Right Cylinder Head
Bolt (Access through Front Cover)
50
37
Fuel Pipe Clip Bolt
7
62
Fuel Pipe Retainer Screw
3
27
Fuel Rail Assembly Bolt
10
89
Ignition Coil Bolt
25
18
Ignition Coil Nut
25
18
Intermediate Drive Shaft Retainer Screw
10
89
Intermediate Shaft Belt Sprocket Bolt
130
96
Knock Sensor
21
15
Lower Intake Manifold Mounting Bolt
13
116
Manifold Absolute Pressure Sensor Bracket Bolt
8
71
40
30
Oil Cooler Hose Fitting
25
18
Oil Distribution Cover Bolt
27
20
Oil Filter
16
12
Oil Filter Fitting
67
49
Oil Level Indicator Bolt
10
89
Oil Pan Bolt-Except Rear
11
97
Oil Pan Bolt-Rear (2)
27
20
Oil Pan Drain Plug
25
18
Oil Pan Nut
11
97
Oil Pan Stud-to-Cylinder Block
10
89
Oil Pressure Switch
32
24
Oil Pump Cover Bolt
10
89
Oil Pump Drive Clamp Bolt
36
27
Oil Pump-to-Rear Main Cap Bolt
54
40
Power Brake Booster Vacuum Pipe Fitting
18
13
Rear Engine Mount Strut Bracket Bolt
82
60
Secondary Air Injection Pipe
25
18
Secondary Air Injection Pipe Nut-Left Side
25
18
Secondary Air Injection Pipe Support Bolt
10
89
Secondary Air Injection Pipe Nut-Right Side
10
89
Serpentine Drive belt tensioner bolt
50
37
Spark Plug
20
15
Throttle Body Adapter Bolt
25
18
Throttle Body Adapter Nut
25
18
Throttle Body Heater Outlet Hose Nipple
18
13
Throttle Body Stud
4
36
Throttle Body Bolt
10
89
Tie Bar Bracket
26
19
Timing Belt Cover Bolt
10
89
Timing Belt Idler Pulley Bolt
50
37
Timing Belt Tensioner Actuator Bracket Bolt
50
37
Timing Belt Tensioner Actuator Pulley Pivot
Bolt
50
37
Timing Belt Tenisoner Actuator Side Plate Bolt
27
20
Timing Chain Tensioner Bolt
27
20
Engine Mount Strut and Engine Lift Bracket
Bolt
70
52
Upper Intake Manifold Retaining Bolt
26
19
Water Inlet Fitting to Front Cover
27
20
Vacuum Source Manifold Mounting Bolt
7
62
Recent Threads
Stuff from our Store
Support this site by buying our stuff!
Powered by vBulletin® Version 3.8.2
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
© 2000-2010, 60DegreeV6.com
Page generated in 0.27025 seconds with 241 queries
