Register Arcade FAQ Community Calendar Today's Posts Search
Go Back   60DegreeV6.com > Specifications > 3400 Engine Specifications
Search Content
Navigation
Motor Articles
In Depth Articles
Miscellaneous
Welcome to 60DegreeV6.com
Welcome to 60DegreeV6.com, the best source for all your GM 60º V6 needs.
If you have a question, please visit the forums and ask there. If you would like to add content to the site, visit the "Create Content" link on the navigation menu. We are always looking for people to add content to the site in order to further expand the site to continue to benefit the community.
3400 Engine Mechanical Specifications
Application
Specification
Metric
English
General Data
Engine Type
60° V-6
Displacement
3.4L
204 cu in
RPO (VIN Code)
LA1 (E)
Bore
92 mm
3.62 in
Stroke
84 mm
3.31 in
Deck Height
224 mm
8.818 in
Compression Ratio
9.6:1
Firing Order
1-2-3-4-5-6
Oil Pressure - Warm
103 kPa
15 psi @ 1100 RPM
Cylinder
Bore
Diameter
92.019-92.037 mm
3.6228-3.6235 in
Out Of Round Maximum
0.007 mm
0.0003 in
Taper -- Thrust Side Maximum
0.010 mm
0.0004 in
Piston
Diameter-Gaged on the skirt 13 mm (0.51 in) below
the centerline of the piston pin bore
91.970-91.988 mm
3.6209-3.6216 in
Clearance
0.032-0.068 mm
0.0013-0.0027 in
Pin Bore
23.006-23.013 mm
0.9057-0.9060 in
Piston Ring
Top Groove Side Clearance
0.04-0.075 mm
0.002-0.0033 in
Second Groove Side Clearance
0.04-0.09 mm
0.002-0.0035 in
Top Ring Gap
0.15-0.36 mm
0.006-0.014 in
Second Ring Gap
0.48-0.74 mm
0.0197-0.0280 in
Oil Ring Groove Clearance
0.48-0.20 mm
0.008 in
Gap with segment at 92.0 mm (3.62 in)
0.25-0.75 mm
0.0098-0.05 in
Piston Pin
Diameter
22.9915-22.9964 mm
0.9052-0.9054 in
Clearance In Piston
0.0096-0.0215 mm
0.0004-0.0008 in
Fit In Rod
(-)0.0469-(-)0.017 mm
press fit
0.0006-0.0018 in
Crankshaft
Main Journal Diameter
67.239-67.257 mm
2.6473-2.6483 in
Main Journal Taper
0.005 mm
0.0002 in
Out Of Round - Max
0.005 mm
0.0002 in
Flange Runout - Max
0.04 mm
0.0016 in
Cylinder Block Main Bearing Bore Diameter
72.155-72.168 mm
2.8407-2.8412 in
Crankshaft Main Bearing Inside Diameter
67.289-67.316 mm
2.6492-2.6502 in
Main Bearing Clearance
0.019-0.064 mm
0.0008-0.0025 in
Main Thrust Bearing Clearance
0.032-0.077 mm
0.0012-0.0030 in
Crankshaft End Play
0.060-0.210 mm
0.0024-0.0083 in
Crankshaft Flange Runout - Max
0.04 mm
0.0016 in
Connecting
Rod
Rod Bearing Journal Diameter
50.768-50.784 mm
1.9987-1.9994 in
Rod Bearing Journal Taper - Max
0.005 mm
0.0002 in
Rod Bearing Journal Out Of Round - Max
0.005 mm
0.0002 in
Rod Bearing Bore Diameter
53.962-53.984 mm
2.124-2.125 in
Rod Inside Bearing Diameter
50.812-50.850 mm
2.000-2.002 in
Rod Bearing Journal Clearance
0.018-0.062 mm
0.0007-0.0024 in
Rod Side Clearance
0.18-0.44 mm
0.007-0.017 in
Camshaft
Lobe Lift (Intake and Exhaust)
6.9263 mm
0.2727 in
Journal Diameter
47.45-47.48 mm
1.868-1.869 in
Camshaft Bearing Bore Diameter-Front and Rear
51.03-51.08 mm
2.009-2.011 in
Camshaft Bearing Bore Diameter-Middle #2 and #3
50.77-50.82 mm
1.999-2.001 in
Camshaft Bearing Inside Diameter
47.523-47.549 mm
1.871-1.872 in
Journal Clearance
0.026-0.101 mm
0.001-0.0039 in
Journal Runout - Max
0.025 mm
0.001 in
Valve System
Roller Lifter
Hydraulic
Rocker Arm Ratio
1.60:1
Valve Face Angle
45°
Seat Angle
46°
Valve Seat Runout
0.050 mm
0.002 in
Seat Width-Intake
1.55-1.80 mm
0.061-0.071 in
Seat Width-Exhaust
1.70-2.0 mm
0.067-0.079 in
Valve Margin - Minimum Intake
2.10 mm
0.083 in
Valve Margin - Minimum Exhaust
2.70 mm
0.106 in
Valve Stem Clearance
0.026-0.068 mm
0.0010-0.0027 in
Valve Spring
Valve Springs Free Length
48.5 mm
1.89 in
Valve Springs Load (Closed)
320 N @ 43.2 mm
75 lb @ 1.701 in
Valve Springs Load (Open)
1036 N @ 32 mm
230 lb @ 1.260 in
Installed Height Intake-Exhaust
43.2 mm
1.701 in
Approx. # or coils
6.55
Oil Pump
Gear Lash
0.094-0.195 mm
0.0037-0.0077 in
Gear Pocket Depth
30.52-30.58 mm
1.202-1.204 in
Gear Pocket Diameter
38.176-38.226 mm
1.503-1.505 in
Oil Pump
Gear
Length
30.45-30.48 mm
1.199-1.200 in
Diameter
38.05-38.10 mm
1.498-1.500 in
Side Clearance
0.038-0.088 mm
0.001-0.003 in
End Clearance
0.040-0.125 mm
0.002-0.005 in
Valve to Bore Clearance
0.038-0.089 mm
0.0015-0.0035 in
Cylinder Head CC
28.6cc
Piston CC
28.6cc
Head Gasket Bore
3.750"
Head Gasket Thickness
.060"
Piston Deck Height
-.020"
Fastener Tightening Specifications (LG8 and LA1)
Application
Specification
Metric
English
Accelerator Control
Cable Bracket Bolt/Nut
10 N·m
89 lb in
Camshaft Position Sensor
Bolt
10 N·m
89 lb in
Camshaft Sprocket Bolt
140 N·m
103 lb ft
Camshaft Thrust Plate
Screw
10 N·m
89 lb in
Connecting Rod Bearing
Cap Nut
20 N·m + 75°
15 lb ft + 75°
Coolant Drain Plug
19 N·m
14 lb ft
Coolant Temperature
Sensor
23 N·m
17 lb ft
Crankshaft Balancer Bolt
103 N·m
76 lb ft
Cap Bolt/Stud
50 N·m +77°
37 lb ft + 77°
Crankshaft Oil Deflector
Nut
25 N·m
18 lb ft
Crankshaft Position
Sensor Bolt -- Front Cover
10 N·m
89 lb in
Crankshaft Position
Sensor Stud -- Side of Engine Block
11 N·m
98 lb in
Crankshaft Position
Sensor Wiring Bracket Bolt
27 N·m
20 lb ft
Cylinder Head Bolt
60 N·m + 95°
44 lb ft + 95°
Drive Belt Shield Bolt
10 N·m
89 lb in
Drive Belt Tensioner
Bolt
50 N·m
37 lb ft
EGR Valve to EGR Valve
Pipe Bolt
25 N·m
18 lb ft
EGR Valve Adapter Pipe
to Exhaust Manifold Nut
25 N·m
18 lb ft
Engine Flywheel Bolt
71 N·m
52 lb ft
Engine Front Cover Bolt
-- Large
55 N·m
41 lb ft
-- Medium
47 N·m
35 lb ft
-- Small
21 N·m
15 lb ft
Engine Mount Bracket
Bolt
58 N·m
43 lb ft
Engine Mount Lower Nut
43 N·m
32 lb ft
Engine Mount Strut and
Lift Bracket Bolt -- Engine Left Rear
70 N·m
52 lb ft
Engine Mount Strut
Bolt/Nut
48 N·m
35 lb ft
Engine Mount Strut
Bracket Bolt -- Upper Radiator Support
28 N·m
21 lb ft
Engine Mount Strut
Bracket Bolt -- Vehicle Right Side
50 N·m
37 lb ft
Engine Mount Upper Nut
47 N·m
35 lb ft
Engine Oil Pressure
Indicator Switch
13 N·m
115 lb in
Engine Wiring Harness
Bracket Bolt
13 N·m
115 lb in
Exhaust Crossover Pipe
Heat Shield Bolt
10 N·m
89 lb in
Nut/Stud
25 N·m
18 lb ft
Exhaust Manifold Heat
Shield Bolt
10 N·m
89 lb in
16 N·m
12 lb ft
Exhaust Manifold Stud
18 N·m
13 lb ft
Fuel Feed Pipe to Fuel
Injector Rail Nut
17 N·m
13 lb ft
Fuel Injector Rail Bolt
10 N·m
89 lb in
Fuel Pipe Bracket
Bolt/Stud
50 N·m
37 lb ft
Fuel Pipe Clip Bolt
8 N·m
71 lb in
Fuel Return Pipe to Fuel
Injector Rail Nut
17 N·m
13 lb ft
Generator Bracket and
Front Engine Lift Hook Bolt
50 N·m
37 lb ft
Heated Oxygen Sensor
42 N·m
31 lb ft
Heater Inlet Pipe Nut
25 N·m
18 lb ft
Ignition Coil Bracket
Bolt/Nut/Stud
25 N·m
18 lb ft
Intake Manifold Coolant
Pipe Bolt
10 N·m
89 lb in
Knock Sensor
19 N·m
14 lb ft
Lower Intake Manifold
Bolt - Center
  • First Pass
7 N·m
62 lb in
  • Final Pass
13 N·m
115 lb in
Bolt - Corner
  • First Pass
13 N·m
115 lb in
  • Final Pass
25 N·m
18 lb ft
MAP Sensor Bolt
5 N·m
44 lb in
Oil Cooler Connector
50 N·m
37 lb ft
Oil Cooler Hose Fitting
19 N·m
14 lb ft
Oil Cooler Pipe Bracket
Bolt
10 N·m
89 lb in
Oil Filter
13 N·m
115 lb in
Oil Filter Bypass Hole
Plug
19 N·m
14 lb ft
Oil Filter Fitting
39 N·m
29 lb ft
Oil Gallery Plug -- 1/4
inch
19 N·m
14 lb ft
Oil Gallery Plug -- 3/8
inch
33 N·m
24 lb ft
Oil Level Indicator Tube
Stud
25 N·m
18 lb ft
Oil Level Sensor Bolt
10 N·m
89 lb in
Oil Pan Bolt
25 N·m
18 lb ft
Oil Pan Drain Plug
25 N·m
18 lb ft
Oil Pan Side Bolt
50 N·m
37 lb ft
Oil Pump Cover Bolt
10 N·m
89 lb in
Oil Pump Drive Clamp
Bolt
36 N·m
27 lb ft
Oil Pump Mounting Bolt
41 N·m
30 lb ft
Spark Plug
  • Spark Plug - Initial Installation
20 N·m
15 lb ft
  • Spark Plug - Reinstallation
15 N·m
11 lb ft
Thermostat Bypass Pipe
to Cylinder Head Nut
25 N·m
18 lb ft
to Engine Front Cover Bolt
12 N·m
106 lb in
to Throttle Body Nut
25 N·m
18 lb ft
Throttle Body Bolt/Stud
25 N·m
18 lb ft
Timing Chain Dampener
Bolt
21 N·m
15 lb ft
Upper Intake Manifold
Bolt/Stud
25 N·m
18 lb ft
Valve Lifter Guide Bolt
10 N·m
89 lb in
Valve Rocker Arm Bolt
19 N·m + 30°
14 lb  ft+ 30°
Valve Rocker Arm Cover
Bolt
10 N·m
89 lb in
Water Outlet Bolt
25 N·m
18 lb ft
Water Pump Bolt
10 N·m
89 lb in
Water Pump Pulley Bolt
25 N·m
18 lb ft
Recent Threads
Stuff from our Store
Support this site by buying our stuff!
Powered by vBulletin® Version 3.8.2
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
© 2000-2010, 60DegreeV6.com
Page generated in 0.25724 seconds with 235 queries
