Search Content
Welcome to 60DegreeV6.com
Welcome to 60DegreeV6.com, the best source for all your GM 60º V6 needs.
If you have a question, please visit the forums and ask there. If you would like to add content to the site, visit the "Create Content" link on the navigation menu. We are always looking for people to add content to the site in order to further expand the site to continue to benefit the community.
3.1L (GEN 2) Engine Specifications
3.1L (Gen II) Engine Specifications
General Data:
All dimensions are in millimeters |
Type |
60 degree V6 |
Displacement |
3.1L |
RPO |
LH0 |
Bore |
89.0 |
Stroke |
84.0 |
Deck Height |
224 |
Compression Ratio |
8.8:1 |
Firing Order |
1-2-3-4-5-6 |
Oil Pressure |
69 kPa @500
RPM; 205-380 kPa @ 2000 RPM
(10 psi @ 500 RPM;
30-55 psi @ 2000R RPM) |
Cylinder
Bore: |
Diameter |
89.017-89.035 |
Out of Round |
0.013 (Maximum) |
Taper - Thrust
Side |
0.02 (Maximum) |
Piston: |
Clearance |
0.022-0.058 |
Piston Ring: |
COMPRESSION |
Groove Clearance
Top |
0.051-0.089 |
Second |
0.051-0.089 |
Gap |
Top |
0.18-0.41 |
Second |
0.51-0.71 |
OIL |
Groove Clearance |
0.2(Maximum) |
Gap |
0.25-0.76 |
Piston Pin: |
Diameter |
22.992-22.997
Clearance |
0.010-0.020 |
Fit in Rod |
0.018-0.046 |
Crankshaft: |
Main
Journal |
Diameter |
67.241-67.265 |
Taper |
0.005 (Maximum) |
Out Of Round |
0.005 (Maximum) |
Main Bearing
Clearance |
0.032-0.077 |
Crankshaft End
Play |
0.06-0.21 |
Crankpin
Diameter |
50.758-50.784 |
Taper |
0.005 (Maximum) |
Out of Round |
0.005 (Maximum) |
Rod Bearing
Clearance |
0.028-0.086 |
Rod Side
Clearance |
0.18-0.44 |
Camshaft: |
Lift |
Intake |
6.68 |
Exhaust |
6.93 |
Journal Diameter |
Journals 1 & 4 |
51.03-51.08 |
Journals 2 & 3 |
50.77-50.83 |
Journal Clearance |
0.03-0.10 |
Valve System: |
Lifter |
Hydraulic |
Rocker Arm Ratio |
1.50:1 |
Valve
Lash |
Intake |
1-1/2 Turns Down from Zero Lash
Exhaust |
Face Angle
(Intake & Exhaust) |
45 degrees |
Margin |
Exhaust |
2.70 |
Intake |
2.10 |
Runout |
0.3 |
Stem Clearance |
0.2-.0.53 |
Valve
Spring |
Free Length |
48.5 |
Pressure
N @ mm |
Closed |
391 @ 40 |
Open |
867 @30 |
Installed Height |
43 |
Valve
Spring
Damper |
Free Length |
48.5 |
Approx # of Coils |
4 |
Fastener Tightening Specifications
Item |
Nm |
Ft Lbs |
Camshaft Sprocket Bolt |
24 |
18 |
Connecting Rod Cap Nut |
50 |
37 |
Crankshaft Damper Bolt |
103 |
76 |
Cylinder Head Bolt (In Sequence) (apply thread sealant to
bolts) |
First Pass |
45 |
33 |
Final Pass |
Add 90 degrees |
*Manifold Side*
6 2 3 7
5 1 4 8
* Outer Side *
Exhaust Manifold Bolt |
28 |
21 |
Flexplate/Flywheel Bolt |
83 |
61 |
Front Timing Cover Case Bolt |
Long |
45 |
35 |
Short |
21 |
15 |
Intake Manifold
(In Sequence) |
First Pass |
20 |
15 |
Final Pass |
33 |
24 |
Main Bearing Cap Bolt |
First Pass |
50 |
37 |
Final Pass |
Add 77 Degrees |
Oil Filter Adapter |
39 |
29 |
Oil Pan Rear Bolts |
25 |
18 |
Oil Pan Bolt and Nut (Except Rear 2) |
6 |
7 |
Oil Pump Bolt |
41 |
30 |
Rocker Arm Nut |
27 |
20 |
Rocker Arm Stud |
25 |
18 |
Belt Tensioner |
54 |
40 |
Throttle Body Bolts |
24 |
18 |
Timing Chain Damper Bolt |
21 |
15 |
Water Pump Pulley Bolt |
20 |
15 |
Water Pump To Block Bolt |
24 |
18 |
Water Pump To Front Cover Bolt |
8 |
10 |
Exhaust Crossover Pipe Nut |
8 |
10 |
Exhaust Heat Shield Nut |
8 |
10 |
Valve Cover Bolt |
8 |
10 |
Recent Threads
Stuff from our Store
