Go Back   60DegreeV6.com > Specifications > 3.1L (GEN 1) Engine Specifications
Search Content
Navigation
Motor Articles
In Depth Articles
Miscellaneous
Welcome to 60DegreeV6.com
Welcome to 60DegreeV6.com, the best source for all your GM 60º V6 needs.
If you have a question, please visit the forums and ask there. If you would like to add content to the site, visit the "Create Content" link on the navigation menu. We are always looking for people to add content to the site in order to further expand the site to continue to benefit the community.
3.1L (Gen I) Engine Specifications
General Data:
All dimensions are in millimeters
Type
60 degree V6
Displacement
3.1L
RPO
LH0
Bore
89.0
Stroke
84.0
Deck Height
224
Compression Ratio
8.8:1
Firing Order
1-2-3-4-5-6
Oil Pressure
69 kPa @500
RPM; 205-380 kPa @ 2000 RPM
(10 psi @ 500 RPM;
30-55 psi @ 2000R RPM)
Cylinder
Bore:
Diameter
89.02-89.03
Out of Round
0.013 (Maximum)
Taper - Thrust
Side
0.013 (Maximum)
Maximum Deck Warpage
0.13
Piston:
Clearance
0.023-0.056
Piston Ring:
COMPRESSION
Groove Clearance
Top
0.051-0.089
Second
0.051-0.089
Gap
Top
0.25-0.51
Second
0.51-0.071
OIL
Groove Clearance
0.20(Maximum)
Gap
0.25-0.76
Piston Pin:
Diameter
22.992-22.997
Clearance
0.010-0.020
Fit in Rod
0.018-0.046
Crankshaft:
Main
Journal
Diameter
67.241-67.267
Taper
0.005 (Maximum)
Out Of Round
0.005 (Maximum)
Main Bearing
Clearance
0.028-0.094
Crankshaft End
Play
0.05-0.2
Crankpin
Diameter
50.757-50.784
Taper
0.005 (Maximum)
Out of Round
0.005 (Maximum)
Rod Bearing
Clearance
0.028-0.094
Rod Side
Clearance
0.18-0.44
Camshaft:
Lift
Intake
6.68
Exhaust
6.93
Journal Diameter
Journals 1 & 4
47.45-47.80
Journal Clearance
0.03-0.10
Valve System:
Lifter
Hydraulic
Rocker Arm Ratio
1.50:1
Valve
Lash
Intake
1-1/2 Turns Down from Zero Lash
Exhaust
Face Angle
(Intake & Exhaust)
45 degrees
Seat Angle (Intake & Exhaust)
46 degrees
Margin
Exhaust
1.55-1.85
Intake
170-2.01
Runout
0.25
Stem Clearance
0.2-.0.8
Valve
Spring
Free Length
48.5
Pressure
Kg @ mm
Closed
41 @ 43.2
Open
98 @ 32.8
Installed Height
39.9
Valve
Spring
Damper
Free Length
48.5
Approx # of Coils
4
Fastener Tightening Specifications
Item
Nm
Ft Lbs
Camshaft Sprocket Bolt 24 18
Connecting Rod Cap Nut 50 37
Crankshaft Damper Bolt 78 58
Cylinder Head Bolt (In Sequence) (apply thread sealant to
bolts)
First Pass 55 41
Final Pass Add 90 degrees
*Manifold Side*
6 2 3 7
5 1 4 8
* Outer Side *
Exhaust Manifold Bolt 24 18
Flexplate/Flywheel Bolt 83 61
Front Timing Cover Case Bolt
8mm 27 20
10mm 38 28
Lower Intake Manifold (In Sequence)
First Pass 20 15
Final Pass 30 22
Upper Intake Manifod Bolt 25 18
Main Bearing Cap Bolt
First Pass 50 37
Final Pass Add 77 degrees
Oil Filter Adapter 68 50
Oil Pan Rear Bolts 25 18
Oil Pan Bolt and Nut (Except Rear 2) 10 8
Oil Pump Bolt 41 30
Rocker Arm Stud 46 35
Belt Tensioner 33 24
Throttle Body Bolts 25 18
Timing Chain Damper Bolt 25 18
Water Pump Pulley Bolt 24 18
Water Pump 24 18
Large 47 35
Medium 21 15
Small 10 8
Exhaust Heat Shield Nut 9 8
Valve Cover Bolt 8 7
Recent Threads
Stuff from our Store
Support this site by buying our stuff!
Powered by vBulletin® Version 3.8.2
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
© 2000-2010, 60DegreeV6.com
Page generated in 0.34613 seconds with 238 queries
