Go Back   60DegreeV6.com > Specifications > 2.8L (VVT) Engine Specifications
Search Content
Navigation
Motor Articles
In Depth Articles
Miscellaneous
Welcome to 60DegreeV6.com
Welcome to 60DegreeV6.com, the best source for all your GM 60º V6 needs.
If you have a question, please visit the forums and ask there. If you would like to add content to the site, visit the "Create Content" link on the navigation menu. We are always looking for people to add content to the site in order to further expand the site to continue to benefit the community.
2.8L (VVT) Engine Mechanical Specifications
Application
Specification
Metric English
General
  • Engine Type
V-6
  • Displacement
2.8 Liter 171 cu in
  • RPO
LP1
  • VIN
T
  • Bore
89 mm 3.5039 in
  • Stroke
74.8 mm 2.9449 in
  • Compression Ratio
10.0:1
  • Cranking RPM - at 40° C (104°F)
80 RPM
  • Idle Speed
600 A/C
Off - 700 A/C On
  • Firing Order
1-2-3-4-5-6
  • Spark Plug Gap
1.1 mm 0.0433 in
Block
  • Crankshaft Main Bearing Bore Diameter
72.867-72.881 mm 2.8688-2.8693 in
  • Cylinder Bore Diameter
88.992-89.008 mm 3.5036-3.5042 in
  • Cylinder Bore Out-of-Round - Production Max.
0.013 mm 0.0005 in
Camshaft
  • Camshaft Bearing Inside Diameter - Front Number 1
35.000-35.020 mm 1.3779-1.3787 in
  • Camshaft Bearing Inside Diameter - Middle and Rear
    Number 2-4
27.000-27.020 mm 1.0630-1.0638 in
  • Camshaft End Play
0.045-0.215 mm 0.0018-0.0085 in
  • Camshaft Journal Diameter - Front Number 1
34.936-34.960 mm 1.3754-1.3764 in
  • Camshaft Journal Diameter - Middle and Rear
    Number 2-4
26.936-26.960 mm 1.0605-1.0614 in
  • Camshaft Journal Out-of-Round
0.006 mm 0.0002 in
  • Camshaft Journal to Bore Clearance
0.040-0.084 mm 0.0016-0.0033 in
  • Camshaft Lobe Duration - Exhaust @ 0.150 mm
    (0.0059 in) Lift
252 degrees
  • Camshaft Lobe Duration - Intake @ 0.150 mm
    (0.0059 in) Lift
237 degrees
  • Camshaft Lobe Lift - Exhaust
42.456-42.756 mm 1.6715-1.6833 in
  • Camshaft Lobe Lift - Intake
42.385-42.685 mm 1.6687-1.6805 in
  • Camshaft Lobe Overlap @ 0.150 mm (0.0059 in) Lift
0 degrees
  • Camshaft Runout - Front and Rear Number 1 and 4
0.025 mm 0.0010 in
  • Camshaft Runout - Middle 2 and 3
0.050 mm 0.0020 in
  • Camshaft Timing @ 0.15 mm (0.0059 in) Lift
  • Valve Opens - Exhaust
-283 degrees BTDC
  • Valve Opens - Intake
14 degrees
ATDC
  • Centerline - Exhaust
118 degrees ATDC
  • Centerline - Intake
132 degrees ATDC
  • Valve Closes - Exhaust
9 degrees
ATDC
  • Valve Closes - Intake
251 degrees ATDC
  • Valve Lift - Exhaust
10.8 mm 0.4252 in
  • Valve Lift - Intake
10.8 mm 0.4252 in
Cooling
System
  • Thermostat Full Open Temperature
95°C 203°F
Connecting
Rod
  • Connecting Rod Bearing Clearance
0.010-0.070 mm 0.0004-0.0028 in
  • Connecting Rod Bore Diameter - Bearing End
59.620-59.636 mm 2.3472-2.3479 in
  • Connecting Rod Bore Diameter - Pin End
24.007-24.021 mm 0.9452-0.9457 in
  • Connecting Rod Length - Center to Center
155.8 mm 6.1338 in
  • Connecting Rod Side Clearance
0.095-0.355 mm 0.0037-0.0140 in
  • Connecting Rod Width - Bearing End
  • Production
21.775 mm 0.8573 in
  • Service
21.770-21.780 mm 0.8571-0.8575 in
  • Connecting Rod Width - Pin End
  • Production
26.000 mm 1.0236 in
  • Service
25.950-26.050 mm 1.0217-1.0256 in
Crankshaft
  • Connecting Rod Journal Diameter
55.992-56.008 mm 2.2044-2.2050 in
  • Connecting Rod Journal Out-of-Round
0.005 mm 0.0002 in
  • Connecting Rod Journal Taper
0.005 mm 0.0002 in
  • Connecting Rod Journal Width
  • Production
22.000 mm 0.8661 in
  • Service
21.920-22.080 mm 0.8630-0.8693 in
  • Crankshaft End Play
0.100-0.330 mm 0.0039-0.0130 in
  • Crankshaft Main Bearing Clearance
0.010-0.060 mm 0.0004-0.0024 in
  • Crankshaft Main Journal Diameter
68.000 mm 2.6772 in
  • Crankshaft Main Journal Out-of-Round
0.005 mm 0.0002 in
  • Crankshaft Main Journal Taper
0.005 mm 0.0002 in
  • Crankshaft Main Journal Thrust Wall
  • Runout
0.000-0.040 mm 0.0000-0.0016 in
  • Square
0.000-0.010 mm 0.0000-0.0004 in
  • Crankshaft Main Journal Width, #2, 4
  • Production
24.000 mm 0.9449 in
  • Service
23.900-24.100 mm 0.9409-0.9488 in
  • Crankshaft Main Journal Width, #3
  • Production
24.400 mm 0.9606 in
  • Service
24.360-24.440 mm 0.9591-0.9622 in
  • Crankshaft Pilot Bearing Bore Diameter
20.965-20.995 mm 0.8254-0.8266 in
  • Crankshaft Rear Flange Runout
0.025 mm 0.0010 in
  • Crankshaft Reluctor Ring Runout - Maximum
2.000 mm 0.0787 in
  • Crankshaft Runout
0.030 mm 0.0012 in
  • Crankshaft Thrust Bearing Clearance
0.076-0.305 mm 0.0030-0.0120 in
  • Crankshaft Thrust Surface - Height Diameter
95.000 mm 3.7401 in
  • Crankshaft Thrust Surface Runout
0.040 mm 0.0016 in
Cylinder
Head
  • Combustion Chamber Volume
49.4 cc 3.015 cu in
  • Valve Guide Bore - Exhaust
6.000-6.020 mm 0.2362-0.2370 in
  • Valve Guide Bore - Intake
  • Valve Guide Installed Height
14.050-14.550 mm 0.5531-0.5728 in
  • Valve Lifter Bore Diameter
12.008-12.030 mm 0.4728-0.4736 in
Lubrication
System
  • Oil Capacity - With or Without Oil Filter Change
5.7 Liters 6 Quarts
  • Oil Pressure - Minimum @ Idle
69 kPa 10 psi
  • Oil Pressure - Minimum @ 2,000 RPM
138 kPa 20 psi
  • Piston Cooling Jet Valve Opening Pressure
1.7-2.3 bar 25-33 psi
Oil Pump
  • Gear Diameter - Outer
87.095-87.175 mm 3.4289-3.4321 in
  • Gear Pocket - Depth
15.565-15.600 mm 0.6128-0.6142 in
  • Gear Pocket - Diameter
87.275-87.325 mm 3.4360-3.4380 in
  • Gear Thickness - Drive/Driven
15.511-15.536 mm 0.6107-0.6117 in
  • Gear-to-Cover Clearance - Drive/Driven
0.030-0.085 mm 0.0012-0.0033 in
  • Gear-to-Housing Clearance - Drive/Driven
0.100-0.230 mm 0.0039-0.0091 in
  • Inner Gear Tip Clearance
0.075-0.180 mm 0.0030-0.0071 in
  • Crankshaft Clearance to Housing
0.040-0.130 mm 0.0016-0.0051 in
  • Inner Gerotor Hub Diameter
53.310-53.335 mm 2.0988-2.0998 in
  • Housing Hub Diameter
53.380-53.420 mm 2.1016-2.1031 in
  • Inner Gerotor Hub Clearance to Housing
0.045-0.110 mm 0.0018-0.0043 in
Piston Rings
  • Piston Ring End Gap
  • First Compression Ring
0.150-0.300 mm 0.0059-0.0118 in
  • Second Compression Ring
0.280-0.480 mm 0.0110-0.0189 in
  • Oil Control Ring
0.150-0.600 mm 0.0059-0.0236 in
  • Piston Ring to Groove Clearance
0.030-0.065 mm 0.0012-0.0026 in
0.015-0.060 mm 0.0006-0.0024 in
  • Oil Control Ring
0.030-0.170 mm 0.0012-0.0669 in
  • Piston Ring Thickness
1.175-1.190 mm 0.0463-0.0469 in
1.470-1.495 mm 0.0579-0.0589 in
  • Oil Control Ring
2.360-2.480 mm 0.0929-0.0976 in
Pistons and
Pins
  • Piston
  • Piston Diameter
88.956-88.974 mm 3.5022-3.5029 in
  • Piston Pin Bore Diameter
24.007-24.012 mm 0.9452-0.9454 in
  • Piston Ring Groove Width - First Compression Ring
1.220-1.240 mm 0.0480-0.0488 in
  • Piston Ring Groove Width - Second Compression Ring
1.510-1.530 mm 0.0595-0.0602 in
  • Piston Ring Groove Width - Oil Control Ring
2.510-2.530 mm 0.0988-0.0996 in
  • Piston to Bore Clearance
0.022-0.032 mm 0.0008-0.0013 in
  • Pin
  • Piston Pin Clearance to Connecting Rod Bore
0.007-0.024 mm 0.0003-0.0010 in
  • Piston Pin Clearance to Piston Pin Bore
0.007-0.015 mm 0.0003-0.0006 in
  • Piston Pin Diameter
23.997-24.000 mm 0.9448-0.9449 in
  • Piston Pin Length
65.24-65.74 mm 2.5685-2.5882 in
Valve System
  • Valves
  • Valve Face Angle
44.25 degrees
  • Valve Face Runout
0.038 mm 0.0015 in
  • Valve Face Width - Exhaust
2.750 mm 0.1083 in
  • Valve Face Width - Intake
2.180 mm 0.0858 in
  • Valve Head Diameter - Exhaust
30.470-30.730 mm 1.1996-1.2098 in
  • Valve Head Diameter - Intake
35.03-35.29 mm 1.3791-1.3894 in
  • Valve Installed Height
35.23-36.69 mm 1.3870-1.4445 in
  • Valve Length - Exhaust
97.11 mm 3.8232 in
  • Valve Length - Intake
101.23 mm 3.9854 in
  • Valve Seat Angle - Seating Surface
45 degrees
  • Valve Seat Angle - Relief Surface
30 degrees
  • Valve Seat Angle - Undercut Surface
60 degrees
  • Valve Seat Runout - Maximum
0.050 mm 0.0020 in
  • Valve Seat Width - Exhaust Seating Surface
1.400-1.800 mm 0.0551-0.0709 in
  • Valve Seat Width - Exhaust Relief Surface
0.700-0.900 mm 0.0276-0.0354 in
  • Valve Seat Width - Intake Seating Surface
1.000-1.400 mm 0.0394-0.0551 in
  • Valve Seat Width - Intake Relief Surface
0.500-0.700 mm 0.0197-0.0276 in
  • Valve Stem Diameter - Exhaust
5.945-5.965 mm 0.2341-0.2348 in
  • Valve Stem Diameter - Intake
5.955-5.975 mm 0.2344-0.2352 in
  • Valve Stem-to-Guide Clearance - Exhaust
0.035-0.075 mm 0.0014-0.0030 in
  • Valve Stem-to-Guide Clearance - Intake
0.025-0.065 mm 0.0010-0.0026 in
  • Valve Lifters
  • Valve Lifter Diameter
11.989-12.000 mm 0.4720-0.4724 in
  • Valve Lifter-to-Bore Clearance
0.037-0.041 mm 0.0015-0.0016 in
  • Rocker Arms
  • Valve Rocker Arm Ratio
1.68 to 1
  • Valve Rocker Arm Roller Diameter
17.740-17.800 mm 0.6987-0.7008 in
  • Valve Springs
  • Valve Spring Coil Thickness
3.250 x 3.900 mm 0.1280 x 0.1535 in
  • Valve Spring Diameter - Inside Top
12.090-12.590 mm 0.4760-0.4957 in
  • Valve Spring Diameter - Outside Top
20.140 mm 0.7929 in
  • Valve Spring Diameter - Inside Bottom
17.950-18.450 mm 0.7067-0.7264 in
  • Valve Spring Diameter - Outside Bottom
26.000 mm 1.0236 in
  • Valve Spring Free Length
42.050-44.850 mm 1.6555-1.7657 in
  • Valve Spring Installed Height - Closed
35.000 mm 1.3779 in
  • Valve Spring Installed Height - Open
24.000 mm 0.9449 in
  • Valve Spring Load - Closed
247-273 N 56-61 lb
  • Valve Spring Load - Open
598-662 N 134-149 lb
  • Valve Spring Total Number of Coils
7.1
Fastener Tightening Specifications
Application
Specification
Metric English
A/C
  • Compressor Bolt - Front
50 N·m 37 lb ft
  • Compressor Bolt - Rear
22 N·m 17 lb ft
  • Compressor Bracket Bolt - Front
50 N·m 37 lb ft
  • Compressor Hose Assembly Bolt
9 N·m 80 lb in
Camshaft
Position Actuator
  • Camshaft Bolt
58 N·m 43 lb ft
  • Oil Control Valve Bolt
10 N·m 89 lb in
Camshaft Cap Bolt 10 N·m 89 lb in
Camshaft Cover Bolt 10 N·m 89 lb in
Camshaft Intermediate
Drive Sprocket Bolt - Idler Sprocket
58 N·m 43 lb ft
Camshaft Position Sensor
Bolt
10 N·m 89 lb in
Catalytic Converter
  • Exhaust Manifold Nut
50 N·m 37 lb ft
Close Out Cover Bolt 10 N·m 89 lb in
Clutch Pressure Plate Bolts 23 N·m 17 lb ft
Connecting
Rod Bolt
  • First Pass
30 N·m 22 lb ft
  • Second Pass - Counter Clockwise
Back Off
to Zero
  • Third Pass
25 N·m 18 lb ft
  • Final Pass
110 Degrees
Coolant Outlet Bolt 10 N·m 89 lb in
Crankshaft
Balancer Bolt
  • First Pass
100 N·m 74 lb ft
  • Final Pass
150 Degrees
Bolt
Inner
  • First Pass
20 N·m 15 lb ft
  • Final Pass
80 degrees
Outer
  • First Pass
15 N·m 10 lb ft
  • Final Pass
110 Degrees
Side
  • First Pass
30 N·m 22 lb ft
  • Final Pass
60 Degrees
Crankshaft Position Sensor Bolt 10 N·m 89 lb in
Crankshaft Rear Oil Seal Housing Bolt 10 N·m 89 lb in
Cylinder
Head Bolt - M8
  • First Pass
15 N·m 10 lb ft
  • Final Pass
60 Degrees
Cylinder
Head Bolt - M11
  • First Pass
45 N·m 33 lb ft
  • Final Pass
120 degrees
Cylinder Head Core Hole Plug 31 N·m 23 lb ft
Drive Belt
  • Idler Pulley Bolt
50 N·m 37 lb ft
  • Tensioner Bolt
50 N·m 37 lb ft
ECM
  • Bolt
10 N·m 89 lb in
  • Bracket Bolt - Front
23 N·m 17 lb ft
  • Bracket Bolt - Side
10 N·m 89 lb in
  • Grounding Bolt
4.5 N·m 40 lb in
ECT Sensor 22 N·m 16 lb ft
Engine
Flywheel Bolt
  • First Pass
30 N·m 22 lb ft
  • Final Pass
45 Degrees
Engine Front Cover Bolt 23 N·m 17 lb ft
Engine Mount
  • Bracket Bolt to Engine Block - M8
38 N·m 28 lb ft
  • Bracket Bolt to Engine Block - M10
60 N·m 45 lb ft
  • Nut to Engine Mount Bracket
80 N·m 59 lb ft
  • Nut to Frame
80 N·m 59 lb ft
EVAP Purge Valve Bolt 10 N·m 89 lb in
Engine Wiring Harness
Bracket
  • Bolt - Cylinder Head Rear
40 N·m 30 lb ft
  • Bolt - ECM Bracket Side
23 N·m 17 lb ft
  • Bolt - ECM Bracket Top
10 N·m 89 lb in
  • Bolt - Left Side Oil Filter Adapter
10 N·m 89 lb in
  • Bolt - Left Side Oil Pan
10 N·m 89 lb in
  • Bolt - Near Crankshaft Position Sensor
50 N·m 37 lb ft
  • Bolt - Right Side Block Front
23 N·m 17 lb ft
  • Bolt - Right Side Head Front
10 N·m 89 lb in
Ground
10 N·m 89 lb in
  • Bolt - Left Cylinder Head Side
10 N·m 89 lb in
  • Bolt - Right Cylinder Head Rear
10 N·m 89 lb in
Exhaust Manifold
  • Bolt
20 N·m 15 lb ft
  • Heat Shield Bolt
10 N·m 89 lb in
Fuel Rail Bolt 10 N·m 89 lb in
Generator
  • Bolt
50 N·m 37 lb ft
50 N·m 37 lb ft
22 N·m 16 lb ft
  • Cable Nut
13 N·m 115 lb in
Ground Cable Bolt 50 N·m 37 lb ft
Heater Inlet/Outlet Pipe Assembly
Bolt
10 N·m 89 lb in
Ignition Coil Bolt 10 N·m 89 lb in
Intake Manifold
  • Brace Bolt - Engine Front Cover M12
65 N·m 48 lb ft
  • Brace Bolt/Ball Stud - Intake Manifold M6
10 N·m 89 lb in
  • Sight Shield Ball Stud
9 N·m 80 lb in
  • Tuning Valve Bolt
10 N·m 89 lb in
  • Upper-to-Cylinder Head Bolt - Long
23 N·m 17 lb ft
  • Upper-to-Cylinder Head Bolt - Short
23 N·m 17 lb ft
  • Upper-to-Lower Intake Manifold Bolt
23 N·m 17 lb ft
Knock Sensor Bolt 23 N·m 17 lb ft
MAP Sensor Bolt 10 N·m 89 lb in
Oil Drain Plug 25 N·m 18 lb ft
Oil Filter Cap 25 N·m 18 lb ft
Oil Filter Housing
Adapter
  • Bolt - Cylinder Head M10
65 N·m 48 lb ft
  • Bolt - Engine Block M8
23 N·m 17 lb ft
Oil Gallery Plug 31 N·m 23 lb ft
Oil Level Indicator Tube Bolt 10 N·m 89 lb in
Oil Level Sensor Bolt 10 N·m 89 lb in
Oil Pan
  • Bolt - Block M8
23 N·m 17 lb ft
  • Bolt - Crankshaft Rear Oil Seal Housing M6
10 N·m 89 lb in
  • Windage Tray Bolt
10 N·m 89 lb in
Oil Pressure Sender 20 N·m 15 lb ft
Oil Pump
  • Bolt
23 N·m 17 lb ft
  • Cover Bolt
13 N·m 115 lb in
Oxygen Sensor
  • Pump Converter Pipe
40 N·m 30 lb ft
PCV Tube Bracket Bolt 10 N·m 89 lb in
Piston Oil Cooling Nozzle Bolt 10 N·m 89 lb in
Power Steering Pump
  • Bracket to Engine Bolt
50 N·m 37 lb ft
  • Pump to Bracket Bolt
22 N·m 16 lb ft
  • Reservoir Bolt - Lower
25 N·m 18 lb ft
  • Reservoir Bolt - Upper
9 N·m 80 lb in
Primary Camshaft Drive
Chain
  • Left Guide Bolt - Oil Pump
13 N·m 115 lb in
  • Tensioner Bolt
23 N·m 17 lb ft
  • Upper Guide Bolt
23 N·m 17 lb ft
Radiator Outlet Pipe
  • Bolt - Generator Bracket
23 N·m 17 lb ft
50 N·m 37 lb ft
  • Bolt - Thermostat Housing
23 N·m 17 lb ft
Secondary Camshaft Drive
Chain
  • Guide Bolt
23 N·m 17 lb ft
  • Shoe Bolt
23 N·m 17 lb ft
  • Tensioner Bolt
23 N·m 17 lb ft
Spark Plug 18 N·m 13 lb ft
Starter Motor
  • Bolt
50 N·m 37 lb ft
  • Cable Nut
13 N·m 115 lb in
Suction Tube Bolt 10 N·m 89 lb in
Suction Screen Bolt 10 N·m 89 lb in
Thermostat Housing Bolt 10 N·m 89 lb in
Throttle Body Bolt 10 N·m 89 lb in
Torque Converter Bolt 60 N·m 44 lb ft
Transmission
  • Mount Bolt to Transmission - RPO M82
60 N·m 45 lb ft
  • Range Selector Lever Nut
9.5 N·m 84 lb in
  • To Engine Bolt
50 N·m 37 lb ft
Water Pump
  • Bolt
10 N·m 89 lb in
  • Pulley Bolt
10 N·m 89 lb in
Recent Threads
Stuff from our Store
Support this site by buying our stuff!
Powered by vBulletin® Version 3.8.2
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
© 2000-2010, 60DegreeV6.com
Page generated in 0.32238 seconds with 235 queries
