Register FAQ Members List Calendar Search Today's Posts Mark Forums Read
Go Back   60DegreeV6.com > Specifications > 2.8L (GEN 2) Engine Specifications
Support the Site!
Like what you see here? Support the site to help us continue to grow.
Search Content
Navigation
Motor Articles
In Depth Articles
Miscellaneous
Stuff from our Store
Support this site by buying our stuff!
Welcome to 60DegreeV6.com
Welcome to 60DegreeV6.com, the best source for all your GM 60º V6 needs.
If you have a question, please visit the forums and ask there. If you would like to add content to the site, visit the "Create Content" link on the navigation menu. We are always looking for people to add content to the site in order to further expand the site to continue to benefit the community.
Latest Garage Images
Garage Image
Chevrolet Beretta
Owner : kflo 93 gt
Garage Image
Chevrolet Beretta
Owner : kflo 93 gt
Garage Image
Chevrolet Beretta
Owner : kflo 93 gt
Garage Image
Chevrolet Beretta
Owner : Jbrogan
2.8L (Gen II) Engine Specifications
General Data:
All dimensions are in millimeters
Type
60 degree V6
Displacement
2.8L
RPO
LB6
Bore
89.0
Stroke
76.0
Deck Height
224
Compression Ratio
8.9:1
Firing Order
1-2-3-4-5-6
Oil Pressure
69 kPa @500
RPM; 205-380 kPa @ 2000 RPM
(10 psi @ 500 RPM;
30-55 psi @ 2000R RPM)
Cylinder
Bore:
Diameter
88.983-89.017
Out of Round
0.013 (Maximum)
Taper - Thrust
Side
0.013 (Maximum)
Piston:
Clearance
0.023-0.056
Piston Ring:
COMPRESSION
Groove Clearance
Top
0.051.089
Second
0.051.089
Gap
Top
0.25-0.50
Second
0.25-0.50
OIL
Groove Clearance
0.199
(Maximum)
Gap
0.25-076
Piston Pin:
Diameter
22.992-22.997
Clearance
0.0064-0.0091
Fit in Rod
Press
Crankshaft:
Main
Journal
Diameter
67.241-67.267
Taper
0.005 (Maximum)
Out Of Round
0.005 (Maximum)
Main Bearing
Clearance
0.030-0.069
Crankshaft End
Play
0.05-0.20
Crankpin
Diameter
50.757-50.785
Taper
0.005 (Maximum)
Out of Round
0.005 (Maximum)
Rod Bearing
Clearance
0.036-0.091
Rod Side
Clearance
0.36-0.68
Camshaft:
Lift
Intake
6.67
Exhaust
6.93
Journal Diameter
47.442-47.790
Journal Clearance
0.02-0.10
Valve System:
Lifter
Hydraulic
Rocker Arm Ratio
1.50:1
Valve
Lash
Intake
1-1/2 Turns Down from Zero Lash
Exhaust
Face Angle
(Intake & Exhaust)
45 degrease
Seat Angle
(Intake & Exhaust)
46 degrease
Seat Runout
(Intake & Exhaust)
0.02
Seat
Width
Intake
1.55-1.85
Exhaust
1.70-2.01
Stem Clearance
0.025-0.069
Valve
Spring
Free Length
48.51
Pressure
Kg @ mm
Closed
40.8 @ 43.2
Open
97 @ 32.79
Installed Height
40.01
Valve
Spring
Damper
Free Length
48.51
Approx # of Coils
4
Fastener Tightening Specifications
Item
Nm
Ft Lbs
Camshaft Sprocket Bolts
24
18
Connecting Rod Bolt Nuts
51
37
Crankshaft Damper Bolt
77
104
Cylinder Head Bolt (apply thread sealant
to bolts)
First Pass
45
33
Final Pass Add 90 Degrees
*Manifold Side*
6 2 3 7
5 1 4 8
* Outer Side *
Exhaust Manifold Bolt
24
18
Flywheel Bolt
71
52
Front Timing Cover Case Bolt
8mm 18-35 13-25
10mm 27-47 20-35
Lower Intake Manifold Bolt
First Pass 22 16
Final Pass 31 23
Upper Intake Manifold Bolt
22
16
Main Bearing Cap 99 73
Oil Pan Bolt
6mm
8-12
6-9
8mm 19-30 14-22
Oil Pump Bolt
41
30
Rocker Arm Nut
24
18
Timing Chain Damper Bolt
20
15
Random Photo Gallery Images
60V6 Photo Gallery
3100 Bad intake damage
Owner : Baldeagle242
60V6 Photo Gallery
2006 NewYork International Auto Show6
Owner : gpse3400
60V6 Photo Gallery
magnacharger install pages
Owner : black05gt
60V6 Photo Gallery
DSCF0614
Owner : bszopi
Search Forums
Tag Search
Advanced Search
Recent Threads
Most Popular Site Articles
Latest poll
What is your current 87 octane gas price?
Less than $3.50
0
$3.50 to $3.75
4
$3.76 to $4.00
13
$4.01 to $4.25
6
More than $4.25
3
Who's online
There are currently 0 users and 30 guests online.
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
© 2000-2008, 60DegreeV6.com
