Register Arcade FAQ Community Calendar Today's Posts Search
Go Back   60DegreeV6.com > Specifications > 2.8L Engine Specifications
Search Content
Navigation
Motor Articles
In Depth Articles
Miscellaneous
Welcome to 60DegreeV6.com
Welcome to 60DegreeV6.com, the best source for all your GM 60º V6 needs.
If you have a question, please visit the forums and ask there. If you would like to add content to the site, visit the "Create Content" link on the navigation menu. We are always looking for people to add content to the site in order to further expand the site to continue to benefit the community.
2.8L (Gen I) Engine Specifications
General Data:
All dimensions are in millimeters
Type
60 degree V6
Displacement
2.8L
RPO
LL2
Bore
89.0
Stroke
76.0
Deck Height
224
Compression Ratio
8.9:1
Firing Order
1-2-3-4-5-6
Oil Pressure
69 kPa @500
RPM; 205-380 kPa @ 2000 RPM
(10 psi @ 500 RPM;
30-55 psi @ 2000R RPM)
Cylinder
Bore:
Diameter
88.992-89.070
Out of Round
0.02 (Maximum)
Taper - Thrust
Side
0.02 (Maximum)
Piston:
Clearance
0.017-0.043
Piston Ring:
COMPRESSION
Groove Clearance
Top
0.030-0.070
Second
0.040-0.095
Gap
Top
0.25-0.50
Second
0.25-0.50
OIL
Groove Clearance
0.199
(Maximum)
Gap
0.27-1.25
Piston Pin:
Diameter
22.9937-23.0015
Clearance
0.0065-0.0091
Fit in Rod
0.0187-0.0515
(Press)
Crankshaft:
Main
Journal
Diameter - 3 Dots
67.241-67.249
Diameter - 2 Dots
67.249-67.257
Diameter - 1 Dot
67.257-67.265
Taper
0.005 (Maximum)
Out Of Round
0.005 (Maximum)
Main Bearing
Clearance
0.032-0.069
Crankshaft End
Play
0.06-0.21
Crankpin
Diameter - 2 Dots
50.758-50.771
Diameter - 1 Dot
50.771-50.784
Taper
0.005 (Maximum)
Out of Round
0.005 (Maximum)
Rod Bearing
Clearance
0.028-0.083
Rod Side
Clearance
0.36-0.60
Camshaft:
Lift
Intake
6.65
Exhaust
6.94
Journal Diameter
47.44-47.49
Journal Clearance
0.026-0.101
Valve System:
Lifter
Hydraulic
Rocker Arm Ratio
1.50:1
Valve
Lash
Intake
1-1/2 Turns Down from Zero Lash
Exhaust
Face Angle
(Intake & Exhaust)
45 degrease
Seat Angle
(Intake & Exhaust)
46 degrease
Seat Runout
(Intake & Exhaust)
0.05
Seat
Width
Intake
1.25-1.50
Exhaust
1.60-1.90
Stem Clearance
0.026-0.068
Valve
Spring
Free Length
48.5
Pressure
N @ mm
Closed
391 @ 40
Open
867 @30
Installed Height
40
Valve
Spring
Damper
Free Length
 47.2
Approx # of Coils
4
Fastener Tightening Specifications
Item
Nm
Ft Lbs
Air Injection Tube
34
25
Air Injection Tube Nut
25
18
Camshaft Sprocket Bolts
23
17
Connecting Rod Bolt Nuts
53
39
Coolant Outlet Bolts
21
15
Coolant Pump Bolts (M6 x 10)
10
7
Coolant Pump Bolts (M8 x
125)
24
18
Coolant Pump Nut
10
7
Cylinder Head Bolts (In
Sequence)
95
70
*Manifold Side*
6 2 3 7
5 1 4 8
* Outer Side *
EGR Valve
25
18
Exhaust Manifold Bolts
34
25
Front Cover Bolts
    -10mm Bolt (4)
50
37
    -8mm Bolt (6)
30
22
Flywheel Bolts
70
52
Intake Manifold Bolts (In
Sequence)
21
15
H D A E I
< Front
G C B F J
Main Bearing Cap Bolts
95
70
Oil Filter Adapter
85
63
Oil Pump Bolt
41
30
Oil Pan Bolts (Rear Two)
25
18
Oil Pan Bolts, Studs and
Nuts
10
7
Oil Pan Drain Plug
25
18
Oil Pump Cover Screws
9
7
Rocker Arm Cover Bolts
8
6
Rocker Arm Studs
65
48
Spark Plugs
30
22
Timing Chain Damper
21
15
Tortional Damper Bolt
95
70
Recent Threads
Stuff from our Store
Support this site by buying our stuff!
Powered by vBulletin® Version 3.8.2
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
© 2000-2010, 60DegreeV6.com
Page generated in 0.53469 seconds with 241 queries
